03-07-2018 12:10
03-07-2018 12:10
Last night (Tuesday) I replaced the battery (which is only lasting one month and not the 6 months is supposed to).
Now my Zip is not syncing (last date/time synced) was yesterday afternoon at 2:47pm CST.
I removed the battery and waited 10 seconds before installing the battery again. I've also checked the time on my mobile device and computer. Times on both are correct.
Still incorrect time and still not syncing. Any help would be greatly appreciated.
Best Answer03-08-2018 06:28
03-08-2018 06:28
Same thing happened to me yesterday! Anyone - How do you fix it.
Best Answer03-08-2018 06:47
03-08-2018 06:47
same thing with me, it showed a full battery, but this morning I shoveled at work and when I got home at 9:30am it was showing a time of 7:00 and the steps were way off and it has a line through the battery.
Best Answer03-08-2018 10:34
03-08-2018 10:34
I would make sure you are installing the battery correctly
Here is a Video on it
https://www.youtube.com/watch?v=Pmzz5df3CaY&t=15s
Wendy | CA | Moto G6 Android
Best Answer03-08-2018 10:38
03-08-2018 10:38
I did install the battery correctly. + side UP. It's showing fully charged.
Best Answer03-08-2018 15:09
03-08-2018 15:09
Awesome help @WendyB! Welcome @bpluskids! I really appreciate that you have confirmed that you have done all the suggested troubleshooting.
Please, confirm that you have restarted your Zip by following this post. If so, you can try setting up your tracker as a replacement device. To do so, please follow this Setup Guide.
I hope this helps, keep me posted! 🙂
03-08-2018 15:46
03-08-2018 15:46
Best Answer03-09-2018 06:15 - edited 03-09-2018 06:16
Thanks for the reply @justjannie! I really appreciate that you have shared your experience with your Fitbit Zip. I wanted to thank you for all the time and effort you have taken to solve this.
To further assist you, I've created a Support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums.
Keep me posted if you have any other question.
