01-08-2018 12:14 - edited 01-08-2018 12:26
Why does my zip calculate less steps than my one did. 1 mile with Zip is just over 1000 steps but when I had the one it was around 2000.
Im 5.4
Best Answer01-08-2018 15:15
01-08-2018 15:15
Welcome to the Forums @SunsetRunner! To further assist you I have a couple of questions:
Keep me posted! 🙂
Best Answer01-08-2018 22:53
01-08-2018 22:53
I had a Fitbit one last year and swapped to a zip. I am doing the same mile walk as I did before but I’m not calculating the same amount of steps. The data is showing the same on the zip and on whe dashboard. The accounts settings were identical.
Cheryl
Best Answer01-09-2018 12:14
01-09-2018 12:14
Thanks for the reply @SunsetRunner! To ensure that your tracker is working correctly, restart it. Also, you can check the placing of your tracker in the help article How do I wear my tracker? It's possible to get different readings if the trackers are worn in different locations.
I hope this helps keep me posted! 🙂
