My zip has been working and synching for a year.
Suddenly now it won't synch. Have changed battery. Restarted zip. Etc etc. Still won't synch.Have good with five and blue tooth turned on. Has something changed since Jan 2018???
Best AnswerMy Zip last sync'd the morning of 1/6/18. It has in the past sync'd thru a dongle to my PC & to my iPhone & iPad. Now none work, so the Zip itself is suspect. It continues to track my activity, but this data stays on the Zip. What can I do to restore this capability? My iPhone bluetooth setting shows several devices not currently connected, but not the FitBit. Should the FitBit Zip show up as a bluetooth device? ...
While tapping my Zip I held my finger on it & then saw the dead battery icon. I replace the battery & immediately sync'd with the iPhone. The results show on my PC. Bluetooth settings on the iPhone still do not show the Zip as a paired device, but it does sync & does show full battery in the FitBit app. When it was not syncing it still showed full battery.
Welcome to the Forums @Janfaulk and @UncleVanya! Thank you for sharing your experience with Fitbit Zip. This helps us to keep improving our products an services.
Please make sure that you are restarting your Zip has described here. Also, you can try the tips on the help article Why won't my Fitbit device sync?
I hope this helps, keep me posted! 🙂
Best AnswerI, too, am having problems syncing. Battery is new and I have followed all suggestions mentioned in this forum with no success. Very frustrating!
