11-14-2017 20:07
11-14-2017 20:07
Since I updated my zip yesterday (11/13) it will sync on my phone. Have uninstalled the app and then reinstalled it, turned phone off/on, and did the same with my bluetooth. Anyone have some ideas.
Best Answer12-01-2017 13:18 - edited 12-01-2017 13:36
Thanks for stopping by @jyy777! Please make sure that you are restarting your Zip as suggested here. Also, I would recommend checking the metal spring inside the Zip's battery compartment. Here is a picture of how it should look like:
And check these tips to fix your syncing issues.
I keep me posted! 😉
