I'm mostly curious to see if anyone else has run into this. To start, my Zip is on the older side, ordered it September 2017.
The past month or so it's only been syncing if I put a new battery in it. Yes, I tried to just restart it with the original battery and that did not very much.
When that stopped working, I put the sticker on the bottom of the battery on the back of the battery and now it's back to syncing if it gets a brand new battery. Sometimes.
Edited for clarity
How you doing my friend? Welcome @WiskiAndRye! ![]()
Thanks for sharing your experience with Fitbit Zip and for the steps that you've tried. The first thing that we need to check is that the little metal contacts on the back of it are well positioned; you can check some helpful information in this post. Also, check if the back is clean and that the battery door is not broken or loose.
Other tips:
Also check this syncing requirements:
If the syncing issue remains with a mobile device I would recommend following the steps below:
If that's not working, we might have to check what is the next options with our support team.
Hi @WiskiAndRye, thanks for trying the suggested steps about the metal contacts. And for your feedback, some other users have noticed that for some reason their Fitbit Zip is only syncing when restarting. You can try the last step that you mentioned and if that doesn't help, we can check your options with our support team.
Keep me posted.
Hi @WiskiAndRye, thanks for getting back. Sorry to hear that it didn't work. I noticed that you had a case with our support team for a syncing issue, please confirm that you've receive the last email from them with your warranty options. Or you can let me know, so I can request them to send again that information.
See you around.
