08-26-2019 07:24
08-26-2019 07:24
Fitbit should know that the zip isn't syncing to the phone app anymore after their recent update. They should fix it. Mine also won't sync unless I remove the battery at the end of the day.
08-26-2019 08:32
08-26-2019 08:32
That's exactly the same problem I'm having.
08-26-2019 11:51
08-26-2019 11:51
Exact problem I am having.
I did find out I can open the back with a penny if I don't have their gadget on me.
08-27-2019 11:20
08-27-2019 11:20
I'm having this problem to after it updated.
Has yours been resolved yet ?
08-29-2019 05:31
08-29-2019 05:31
I have been in touch with fitbit via twitter and email and they still haven't fixed the problem. I have told them to check the fitbit forum to see how people are having this problem. After doing everything I can think of and all of the tech support suggestions I still have the problem.
08-29-2019 06:30
08-29-2019 06:30
I keep trying to sort it out but nothing either.
I think it's a ploy to make us buy new fit bits that will syn with the new app 😨
08-29-2019 06:31
08-29-2019 06:31
I have to remove my phone battery and also my fitbit battery too.....it's a pain 😨
08-29-2019 07:56
08-29-2019 07:56
I am having the same problem.
08-29-2019 08:50
08-29-2019 08:50
I saw a reply somewhere on this site that a person ordered a new zip and it wouldn't sync the steps either and they returned it.
08-29-2019 08:53
08-29-2019 08:53
Oh hell...we have had it then.
Fitbit definitely need to sort this out for us x
08-29-2019 10:42
08-29-2019 10:42
Thank you very much...I'll do it now 😁
08-29-2019 12:30
08-29-2019 12:30
Mine won't sync unless I take the battery out.
08-29-2019 12:43
08-29-2019 12:43
Mine started to have problems a couple of days before the update. Mine won't sync unless I remove the battery. Seems ridiculous and I'm not spending money on a new one as this works just fine otherwise.
08-29-2019 13:22
08-29-2019 13:22
Last time mine synced with My Fitness Pal app was on August 12th. Since then I have tried all of the "fixes" numerous, numerous times. I have no use for this device if it won't sync. Extremely frustrating.
08-29-2019 14:40
08-29-2019 14:40
It's so annoying isn't it 😠
08-29-2019 14:42
08-29-2019 14:42
Yes I agree....mine was fine too before the update 😭
08-29-2019 14:44
08-29-2019 14:44
Very very annoying...I can't get anywhere when I rung fitbit either 😭
Best Answer08-29-2019 16:44
08-29-2019 16:44
Sucks! I have the same problem after the update. I don’t want to get a new Fitbit cuz I don’t like to wear watch!
08-29-2019 19:26 - edited 08-29-2019 19:28
Mine has had issues since 3 days before the update. I had researched purchasing another Fitbit zip but unfortunately found out they discontinued it. Amazon sells them for $129.
I wonder if they are trying to get everyone to buy Fitbit watches. If so I will switch over to Garmin, since they still have a clip-on tracker.
08-30-2019 07:46
08-30-2019 07:46
DO you all know what other clip on trackers work with MYFITNESSPAL
