01-30-2019
18:33
06:21
MarcoGFitbit
01-30-2019
18:33
06:21
MarcoGFitbit
I have read all the comments, My Fitbit 3 keeps saying on my Apple phone Connection Unsuccessful, Make sure "Charge 3" is turned on and in range. It was connected last night after I said forget this device and back to square one. I'm over it! How many times can you reboot both phone and watch. Not Happy 😞
05-24-2020 03:43
05-24-2020 03:43
06-04-2020 14:25
06-04-2020 14:25
Ha! I've gone back to using my zip. Wish they still made that.
06-09-2020 08:32
06-09-2020 08:32
I have done everything you have said to do and now my Charge 3 in not connecting at all. Even tried to pair with other devices but getting the same issue.
Think it is the charge 3 that has the issue as it is also not keeping the correct time.
Really not happy bubby got it for me before Christmas last year.
06-10-2020 09:01
06-10-2020 09:01
This has been going on for the past several days and I don’t know what to do I’ll see you about getting a new Fitbit but is it the Fitbit or should I get an Apple Watch
06-10-2020 13:00
06-10-2020 13:00
06-12-2020 03:48
06-12-2020 03:48
06-12-2020 03:49
06-12-2020 03:49
06-12-2020 05:36
06-12-2020 05:36
Just ben on Live Chat for 2nd time all advice helped then following day realised it had not sync'd once from when I last chatted to chap and clock was wrong, every day I am still having issues.
Just went on chat Live with FitBit and the lady ended conversation and I now cannot link my watch to the app with a watch with wrong time and was told to continue to sync it.
How am i suppose to do that when it won't even connect to app.
Now have to wait for the Higher Support team to get back to me now.
06-12-2020 09:07
06-12-2020 09:07
06-12-2020 09:09
06-12-2020 09:09
06-17-2020 18:23
06-17-2020 18:23
So I first purchased in January, replaced in April no I am getting my second replacement. Something is very wrong with the charge 3. They also wasted my time trying to get me to do all the things I had already tried.
I have ordered a garmin vivoactive 4s and will have my daughter use the fitbit until it dies again.
Very disappointed in fitbit. I only switched because I could switch out bands. My 4 or 5 year old garmin works fine but the band broke and I can't replace it.
On a side not the original fitbit band made me breakout in less than 1 day also never a problem with garmin.
06-18-2020 07:57
06-18-2020 07:57
06-22-2020 04:39
06-22-2020 04:39
06-24-2020 19:04
06-24-2020 19:04
My Charge3 is “Not Connected” more than it is “Connected” - becoming a real pain - obviously not a new problem
06-25-2020
12:49
09:53
06-25-2020
12:49
09:53
Hi everyone. It's good to see you participating in the Community Forums.
Thanks for the information provided and the steps tried prior posting. I see where you're coming from about this situation since your Charge 3 should be able to sync correctly, I'm sorry that you're having this experience. Just to double check, please make sure your iOS device and the Fitbit app are updated. If that's correct, I'd recommend to give a try to the following steps:
If you continue having syncing issues, I'll need you to provide me with the model of your iOS device and the OS/software version so I can further investigate.
I'll be around, keep me posted.
06-26-2020 04:58
06-26-2020 04:58
06-26-2020 05:05
06-26-2020 05:05
06-26-2020 05:09
06-26-2020 05:09
06-26-2020 06:37
06-26-2020 06:37
06-29-2020
14:09
09:52
06-29-2020
14:09
09:52
Hi @lajmoran @Jillianaponte77, thank you for your replies.
@lajmoran thank you for sharing the details of the issue with your Charge 3. I am sorry that you are going through this situation, I totally understand how you are feeling and appreciate your input. Upon checking with our Support team, I was told that you have already contacted them and that they were able to assist you. Thank you for your time and efforts.
@Jillianaponte77 I understand that this can be very frustrating and appreciate your feedback since this helps us to keep improving. I would like to confirming if the steps provided previously helped you to sync your tracker? I also recommend to keep the app up-to-date as the updates come with new features and bug fixes.
Looking forward to hearing back from you.
