I can see my sleep info - from the app I click on the sleep tile. Then click on the day I want to see, then click on the arrows that are in the upper right (to expand that graph), then I can drag my finger across the graph to see actual times for each area.
Hope that may help you...
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Best AnswerUp until the update on 17 August, it was absolutely fine. The update broke it for me, and it looks like a lot of others as well. It is still broken, three days later.
I am on the latest update - V2.26 - doing those actions allows me to see my times. Not sure why you can't?
Here is a post from moderator explaining it as well with some tips that may help. https://community.fitbit.com/t5/iOS-App/Sleep-tracker-no-longer-responding-to-finger-drag/m-p/152123...
Kelly | Oklahoma
@Jchchatt Yes - IPhone 6+. It may not be working correctly since you mentioned you are not on the latest version of the App.
Kelly | Oklahoma
Best AnswerHad the issue, then thought perhaps it was becasue I needed an iOS update. Updated the iOS to no avail. Standard iPhone 6 (not +), up-to-date app, up-to-date iOS. I even went looking for a way to roll back to the prviosu version, but that failed, too...
Best AnswerI just posted over in the thread @Kmransom123 posted above - so hopefully the moderator there will respond and shed some light for me/us 😕
Good thinking - they may have more info/ideas for you all to try. ![]()
Kelly | Oklahoma
@JadziaOz I will try my best!
@Jchchatt @Kmransom123 @gmak49 @Rei_Li So if you click the sleep tile on your iOS dashboard > click the diagonal arrow button in the top right corner to expand the graph > and then tap and hold a specific time on the expanded graph, it will show the specific times for when you were asleep, restless, or awake.
I believe for the previous version of the App you just had to tap to see the specific times, where with the latest version you have to tap and hold to see the specific times.
Hope this provides some clarity!
