02-28-2018
11:21
05:07
MarcoGFitbit
02-28-2018
11:21
05:07
MarcoGFitbit
So since the last firmware update, my iPhone is typically losing 20% of its battery life over night and with ONLY the Fitbit app open.
This seems to be new since most recent firmware (Ionic) update.
I do have "All-Day Sync" selected but that's changed. This appears to be significantly more battery consumption than previously experienced.
03-01-2018 05:10
03-01-2018 05:10
Hello @rhgood, I hope you're doing well, it's nice to see you around. ![]()
Thanks for bringing this to my attention. Please keep in mind that if you have "All-day Sync" enabled, your phone and your tracker will try to find each other constantly, meaning that the battery consumption on both devices will increase significantly. If you have "All-day Sync" enabled due to Notifications coming from your phone, take in consideration that turning ON the Bluetooth on your phone will be sufficient.
In order to prevent your phone battery from draining faster than usual, please disable "All-day Sync" and monitor your phone for the next 24 hours to check if this improves.
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
03-01-2018 09:37
03-01-2018 09:37
Not helpful at all...
I said in my email that things are different now.
I have not changed the "all-day sync" setting. I understand how it works.
Best Answer11-01-2018 23:28
11-01-2018 23:28
How do I disable all day sinc
Best Answer11-07-2018 07:09
11-07-2018 07:09
Hello @Fkohn, thanks for joining the conversation, it's always a pleasure for me to welcome you to the Fitbit Community. ![]()
I appreciate your participation in the Forums and for posting your question. In order to disable All-day Sync, go to the Fitbit app and tap on Account > your device and scroll down. You will be able to enable/disable All-day Sync by tapping on it.
I hope this resolves your inquiry, if there's anything else I can do for you, please feel free to reply.
07:52
07:42
MarcoGFitbit
11-07-2018
07:52
07:42
MarcoGFitbit
Thank you. I returned the fitbit but thanks for your response.
Francine Kohn
Moderator Edit: Removed Personal Information.
Best Answer11-08-2018 07:44
11-08-2018 07:44
Hello @Fkohn, I hope you're doing well, thanks for taking the time to reply. ![]()
I appreciate you have come back, you're very welcome. I'm very sorry to hear you've returned your Fitbit device and I sincerely apologize for the inconveniences you've experienced.
Thanks for keeping us updated, have a great day!
