02-03-2022
03:31
09:35
DavideFitbit
02-03-2022
03:31
09:35
DavideFitbit
How do I request a return authorization number ?
02-03-2022 06:45
02-03-2022 06:45
Hi @Acit you can only get a return authorization number (RMA) if you're within the window to return the device for a refund OR if customer support has decided that you need to return it for a replacement. What's going on?
02-03-2022 10:14
02-03-2022 10:14
02-03-2022 10:25
02-03-2022 10:25
Ahh, ok, that makes sense. When and where did you buy it? Fitbit.com has a 45 day return window from date of purchase. Other retailers have different time frame for return/exchange.
02-03-2022 10:57
02-03-2022 10:57
02-03-2022 11:00
02-03-2022 11:00
@Acit when did you order it?
02-03-2022 11:10
02-03-2022 11:10
January 2nd, 2022
02-03-2022 11:25
02-03-2022 11:25
https://myhelp.fitbit.com/s/support?language=en_US
02-04-2022
09:32
06:15
02-04-2022
09:32
06:15
Hi, welcome to the Community forums, @Acit.
Thank you for sharing your inquiry on how to return an Ace 3 that you purchased through the online store.
As @Odyssey13 has kindly mentioned earlier, it would be necessary to get in touch with the Customer Support team for further assistance with the return process. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
See you around.
02-07-2022 14:34
02-07-2022 14:34
The link opens a blank page. The website is a maze probably designed to ensure that you keep what you buy.
02-07-2022 14:42
02-07-2022 14:42
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Try a phone call. Sometimes there isn't someone there, so you can't see the link to chat.
02-07-2022 15:12
02-07-2022 15:12
02-07-2022 15:24
02-07-2022 15:24
Pretty sure Canada is the US number
02-12-2022
16:08
06:14
02-12-2022
16:08
06:14
@Acit I just tried to open the link mentioned earlier, but it's working properly on my end.
However, I noticed that @Odyssey13 provided you with the direct numbers to contact the Support team. The number for the US would be the same one that you need to use for Canada.
Thanks again for sharing all your feedback.
See you around.
