09-10-2022 08:59
09-10-2022 08:59
hi, so we bought my daughter a fit bit ace 2 a few years ago. Barely used. Decided were going to give it to a family members child. I've requested to delete the account from the family account and it says it takes 7 days. My question is will the fit bit factory reset after this? I've tried everything to get it to factory reset and cannot do it. Can anyone help? Thanks
Best Answer09-10-2022 11:27 - edited 09-10-2022 11:33
Hello @Kylie2704
Factory reset can be a bit confusing on an Ace 2. It’s done so by design so that a child can’t accidentally do a factory reset on their own. But I’ll be more then happy to help you out.
You can easily remove the individual associated to the Ace 2 by following these instructions:
To factory reset the Ace 2: First place the Ace 2 into its charger and charge it. While it’s in the charger go to the settings (gear wheel) and tap it. Now scroll down to clear data user. When prompted, press the screen for 3 seconds and release. When your tracker vibrates and the clock screen appears, your data is erased.
Giving the Ace 2 to a family members child won’t be an issue. Just have the new child’s parent set up a family account like you did and then add the Ace 2 to the account as if it was brand new.
😃I hope this gives you the best answer to your question and helps get the Ace 2 prepared for a new home. Please come back and let me know.
Hello @Kylie2704
Best Answer09-10-2022 15:10
09-10-2022 15:10
Best Answer09-10-2022 15:27 - edited 09-10-2022 15:29
Hello again @Kylie2704
Your fine about the family account you have. It will close itself. The Ace 2 is erased and ready to be gifted to someone else. Your all set. 😃 I am happy I could help and I hope the next child enjoys the Ace 2. Please consider marking my previous instructions on how to clear everything as “Best Answer”. Doing so helps others in a similar situation find answers quickly. I’d appreciate it. Enjoy the rest of your weekend and as always Happy Stepping!
