11-21-2018 03:27 - last edited on 08-20-2020 20:08 by MatthewFitbit
Hi,
This morning my screen has decided it doesn't want to display anything when I tap or swipe it. My battery is half charged and I have tried doing a reset of my tracker but to no avail.
Thanks
Moderator edit: Updated title for clarity
05-18-2021 08:57
05-18-2021 08:57
Hi Ferdinand
My Alta HR is doing the same thing. I tried to reboot it as you stated to Kiela but nothing happened. I still have the back screen. It vibrated when I pushed the button on my charger and/or when I attached the charger but nothing appeared /appears on the screen at all. What else can be done?
05-18-2021 11:27
05-18-2021 11:27
05-18-2021 13:48
05-18-2021 13:48
05-18-2021 16:16
05-18-2021 16:16
05-26-2021 13:03 - edited 05-26-2021 13:28
My Alta HR won't show the display. When I go through the procedure as described, it vibrates after every push of the button but still no display. It also buzzes every time I remove and then reattach the charger but still no display. Has it reached the end of its life or is there a fix I don't know about?
05-26-2021 13:18
05-26-2021 13:18
05-27-2021 02:48 - edited 05-27-2021 03:11
Rebooted three times and everything is working fine now. Glad I didn't throw it away. [Edit] It only shows " ! " what does it mean?
05-27-2021 10:17
05-27-2021 10:17
Thanks. I did try rebooting several times. The display did flicker a few times but now nothing. I've had it since 11/2018 - disappointed it didn't last longer.
06-16-2021 10:48
06-16-2021 10:48
I am having the same issue, but when I attempt a restart nothing happens. I feel the vibration when I press the button on my charger, but no Fitbit logo appears.
My screen does not display anything even though it still syncs to my phone.
please help!
thanks
06-20-2021 19:25
06-20-2021 19:25
I followed the instructions given and my HR is not charging?
06-20-2021 19:39
06-20-2021 19:39
I decided there was no point in trying to get my Alta HR to work anymore and now have a Charge 4 and so far am very happy with it.
07-04-2021 00:19
07-04-2021 00:19
I have the same issue. Tried restart using the charging cable and it doesn’t work.
I hadn’t used the device for a few months and charging it the screen won’t display anything. It will sync with the Fitbit app, but nothing on the display.
07-04-2021 00:34
07-04-2021 00:34
07-04-2021 06:00
07-04-2021 06:00
07-04-2021 22:03
07-04-2021 22:03
Thanks! It worked for me too
02-26-2022 12:57
02-26-2022 12:57
black/blank screen even after reset and fitbit alta hr fully charged
07-11-2022 19:22
07-11-2022 19:22
What button would that be ?
01-02-2023 15:34
01-02-2023 15:34
What button on the charger cable??
06-18-2023 14:49
06-18-2023 14:49
Our Fitbit Altas are several years old and haven’t been used lately. Trying to power up. One showed a full battery, but then later would not show anything. The other never showed anything. Can the Alta’s just become dead?
06-18-2023 15:16
06-18-2023 15:16
