06-30-2016
23:37
18:17
06-30-2016
23:37
18:17
When I put my Alta to charge it started to get hot and suddenly stopped working. I have only had it a few months and follow the clean and care tips well. I have tried resetting it but anytime I put it on the charger it starts to heat up. Has this happened to anyone else? Is there any way to get this fixed or would I have to get it replaced?
Moderator edit: edited title for clarity
Hi, @lmendoza, it sounds like this is something you should contact Customer Support about -- contact.fitbit.com -- they will be able to help.
Welcome to the Community.
Also if you bought it else where other than Fitbit it would be faster to return it there.
Wendy | CA | Moto G6 Android
@lmendoza I was notified that our Support Team has reached out to you via email. I recommend checking it out and responding as soon as possible so our team can help you get back to stepping. Keep me posted.
The same thing just happened to me now! I went to charge it because leaving to go on vacation and it shut off and got hot when I put it on the charger! I am freaking out because I am going hiking!!!!
@kmadalena how were you charging it - via the computer or an electric usb cord?
At most you'll need to do a restart of the device.
i had the same issue this morning as well. it wasn't syncing to the tracker. so i tried to restart the tracker by pushing the button 3 times when connected to the wall socket, then tracker display when black.
After which, no matter how many times i try, there isn't any response from the tracker, not even a vibration. The tracker will heat up when connected to the charger though.
Can't seem to get it to respond at all but was very low in power when the problem started - using my charger plugged into my computer
Best AnswerI have the same thing. I want to know if anyone ever resolved the problem?
@lmendoza wrote:When I put my Alta to charge it started to get hot and suddenly stopped working. I have only had it a few months and follow the clean and care tips well. I have tried resetting it but anytime I put it on the charger it starts to heat up. Has this happened to anyone else? Is there any way to get this fixed or would I have to get it replaced?
Nice to see you here @kwmomma and @lmendoza! Thanks for sharing your experience with your Fitbit. To further assist you, I've created a Support Case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums.
Keep me posted if you have any other question.
