06-18-2016
19:17
18:17
06-18-2016
19:17
18:17
My battery is only lasting for a day. Previously it had been lasting longer. It is less than a month old.
10-04-2019 18:44
10-04-2019 18:44
How do you turn off the display every time you move your hand
Best Answer12-06-2019 10:27 - edited 12-07-2019 06:41
I have tried all of these suggestions. I have even removed a bunch of apps I had on it.
Power still only lasts 24 to 36 hours. It used to be about 4 days before it had to be charged
01-06-2020 22:14
01-06-2020 22:14
So what did they have toy sli that was so impressive? Fitbit battery world fine charging only 5-7 days. Now I have charged twice a day. I did all the troubleshooting and reset... still charges slow and rumer holds a full day.
Best Answer01-19-2020 18:00
01-19-2020 18:00
Mine wont even reset. Every-time i try to reset it it just stops the band from charging and restarts the charge. I'm seriously considering giving Fitbit the flick as this is my 3rd tracker with them and the customer service has been woeful and highly underwhelming with my last two trackers .
Best Answer01-21-2020 10:42
01-21-2020 10:42
Best Answer03-03-2020 14:03
03-03-2020 14:03
I tried cleaning the contacts and resetting my Alta Fitbit HR. During reset, the Fitbit logo never appeared. Because of the shorter battery life, the device recently died completely. When connecting to recharge, the Fitbit logo appeared so I was hoping there was a reset and the problem was resolved. Unfortunately, that isn’t the case. If I have to replace my Fitbit (again), it may be time to select another product. I could have purchased an Apple Watch with the amount I’ve spent on Fitbits. ☹️
Best Answer03-03-2020 14:29
03-03-2020 14:29
