09-06-2017
15:42
18:17
09-06-2017
15:42
18:17
The screen brightness on my Alta is very dim and unreadable in all but the lowest light. I have tried to reset the device but it has made no difference. Can anyone help?
Thanks.
09-07-2017 07:08
09-07-2017 07:08
@Verading Thanks for participating in our Fitbit Community! Sounds weird that your Alta's display is dim. I would like to know if this issue affects the display all the time or if the display is dim when you are outside when the sunlight hits your tracker.
Looking forward to your response my friend! ![]()
09-07-2017 12:39
09-07-2017 12:39
09-12-2017 05:09
09-12-2017 05:09
@Verading Thanks for getting back! I would like to know just one more detail; did your Alta experience any intense contact with water or liquids? This also may affect the functionality of the display.
In the meantime, try the restart process 3 consecutive times and see if the display issue gets corrected.
Let me know how it goes my friend! ![]()
Best Answer09-12-2017 09:40
09-12-2017 09:40
Best Answer09-14-2017 06:24
09-14-2017 06:24
@Verading I'm so glad to hear that our Support team was able to replace the defective unit! Thanks for keeping the update here. Than you also for sharing your feedback and comments. This info helps us to keep improving our services and products.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often my friend! ![]()
01-07-2018 09:50
01-07-2018 09:50
My fitbit is brand new and cannot read the display outdoors. I have tried to reset as described, but, does not change anything. Useless product for me, I bought it to keep track of my outdoor walks...
01-08-2018 14:58
01-08-2018 14:58
01-11-2018 05:52
01-11-2018 05:52
@FiddletownR Thank you for joining us in this thread! I know how frustrating the display is for you since it's hard to view it when the sunlight hits directly to your tracker. The Alta doesn't have an option to adjust the brightness of the display. I really appreciate your feedback and comments.
@Verading Thanks for your input and feedback my friend!
I'll be around if more questions arise! ![]()
Best Answer03-23-2018 06:07
03-23-2018 06:07
That's pretty stupid since 99% of the time you are outside
03-26-2018 04:19
03-26-2018 04:19
@PeggyO507 I really appreciate your feedback about the brightness of the Alta. I understand your frustration about this. Please check out this Feature Request so you can have more details about this.
See you later my friend! ![]()
Best Answer06-05-2018 15:31
06-05-2018 15:31
My Alta has the same problem with dim display..... can't read the display at all outdoor. Tried to reset the Alta several time but no improvements. Can someone offer suggestions?
06-06-2018 06:11
06-06-2018 06:11
@AW04 Welcome to our Fitbit forums! Regarding your inquiry, I'd like you to take a look at MaginFitbit's post which explains more information about the display's brightness.
Let me know if you have additional questions! ![]()
Best Answer02-07-2019 02:50
02-07-2019 02:50
I cannot read anything on my Fitbit Alta. I have done a reset. the screen is dim. Can i open the device? Is there a battery to be replaced?
02-09-2019 05:57
02-09-2019 05:57
@Blo1 Welcome to our Fitbit Community! I'm sorry to hear that your Fitbit Alta's screen is hard to be read. Regarding your inquiries, the device can't be opened and the battery is built in. Therefore the battery can't be replaced.
Since you already tried to restart it, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You'll receive an email from them soon.
Let me know if you have any doubts! ![]()
05-23-2019 08:55
05-23-2019 08:55
Hi - have had my Alta HR for about 16 months. Over the last week or so the heart rate and active minute tracking has been very off. Today the display screen became so dim that I can only read it if I cover it with my hand to create a low light effect. Can't think of anything that could have caused water damage - certainly not in the last week when it stopped functioning properly. Let me know any advice.
05-24-2019 01:30
05-24-2019 01:30
Well noted. I am on standby.
Best Answer07-15-2019 14:36
07-15-2019 14:36
I have had my Alta for a few years. I have just taken it out of the drawer to begin using again. It is fully charged. The screen is too dim to see when outside. Is there anything I can do?
Best Answer07-15-2019 15:39
07-15-2019 15:39
This is a known issue with the Alta....nothing can be done.
Best Answer07-15-2019 17:31
07-15-2019 17:31
