01-06-2020
15:57
20:01
01-06-2020
15:57
20:01
Hi there.
I have been having issues with syncing my Altra HR to my app (got a onePlus6T phone)
This has been an issue since early December.
I have tried all suggested solutions.
So far, I have to de and re-install the app, restart the phone and re-connect the Fitbit before it syncs ONCE. After that, it stops working.
Never had this issue before, but it seems to persist.
Please help
01-07-2020 09:53
01-07-2020 09:53
Last syn on 29 Dec 2019, then no data can be synchronized on the app.
Is there any problem with the app updates?
Please help, thanks!
Best Answer01-08-2020 09:26
01-08-2020 09:26
Similarly I have had to restart my phone several times lately before my Alta HR would sync updated data. It seems to work for a few hours maybe before it loses connection and I have to restart my phone again (this has been the only option I have found to even temporarily connect again). My phone is Samsung Galaxy S7.
Best Answer01-09-2020 04:47
01-09-2020 04:47
Yes, it's a known issue. Sometimes it will sync after rebooting your phone. I can see my Altra HR under Bluetooth devices in Settings\Bluetooth Devices. But the Fitbit App can't see it. You can also delete the device from the pairings screen and re-pair it. I have seen where reinstalling the App will allow you to sync also.
