02-11-2019
15:50
20:08
02-11-2019
15:50
20:08
I noticed one day last week that my display on my Alta HR is messed up. It's like the top half is "scrambled". I have gotten it wet or damaged it in any way.
Anyone else have this issue? Is it fixable? I've had this fitbit for about a year or so.
Any help would be appreciated.
02-11-2019 19:01
02-11-2019 19:01
Sounds like you're having the same problem as me, does it kind of look like this?
02-12-2019 00:59
02-12-2019 00:59
Mine isn’t that bad.
Best Answer02-12-2019 02:41
02-12-2019 02:41
Hi @Ruth407 @SunsetRunner
If you havent already tired, restart your teacker several times. I have flagged this thread for a moderator to give further assistance to you both.
Helen | Western Australia
02-12-2019 06:29
02-12-2019 06:29
Welcome to the Fitbit Forums @Ruth407 and @SunsetRunner! It´s nice to see you here.
I´ll be glad to assist you with your Alta HR display inquiry. Thank you for letting us know that you haven´t gotten it wet or damaged it.
@Ruth407, that´s how your device should look like. It´s not an error.
@SunsetRunner, have you tried @NellyG´s advise?
I´ll be waiting for your response.
Best Answer02-12-2019 09:48
02-12-2019 09:48
My issue is currently being looked into by the support team 🙂
Best Answer02-12-2019 09:56
02-12-2019 09:56
Thanks for getting back to us and for letting us know that you already have been helped by our support team @SunsetRunner.
Keep on visiting our community! ![]()
12:23
12:55
AndreaFitbit
02-12-2019
12:23
12:55
AndreaFitbit
So part of the numbers should be missing?! It was NEVER like that until a few days ago.
This may be a better pic.
Mloderator edit: updated post.
Best Answer02-12-2019 12:57
02-12-2019 12:57
Thanks for getting back to us and for providing a better picture of your device @Ruth407. Could you please confirm that you have restarted your Alta:
I'll be waiting for your response.
Best Answer02-12-2019 19:27
02-12-2019 19:27
Yes. I reset it no less than 10 times.
Thanks gor for all your assistance.
Best Answer02-19-2019 01:37
02-19-2019 01:37
I still don’t have a solution for my issue.
Best Answer02-22-2019 07:44
02-22-2019 07:44
Hi there @Ruth407 ! 🙂 Great to see you in the Forums! 🙂
Thanks for getting back with us and trying to restart your tracker. I'm sorry that you'r estill having problems with this.
I've escalated your case to our Support Team for them to help you out with this. Please, keep an eye on your inbox for more instructions and if you need more help, feel free to let me know!
09-07-2019 09:48
09-07-2019 09:48
I am also having problems with my Fitbit Alta HRscreen being scrambled. I have alsonot gotten wet and have reset and thats not working.
Best Answer09-07-2019 09:53
09-07-2019 09:53
I am also having thr sane issue started last week I have reset still not working and I have not gotten wet had less than a year.
Best Answer09-07-2019 09:55
09-07-2019 09:55
My look just like yours did you get a workaround to fix this?
Best Answer05-17-2020 19:21
05-17-2020 19:21
Display is corrupted and jumbled it’s almost like it’s reversed. Have tried to reset it several times
Best Answer05-23-2020 14:04
05-23-2020 14:04
I am having the same issue. I called Fitbit Tech Support and they said that mine was out of warranty and they offered me a coupon for 25% off one of their current models. I'd really like to resolve this faulty unit.
Best Answer09-01-2020 15:48
09-01-2020 15:48
I've been having this problem with my tracker for a few weeks now. Seems to be intermittent, and I've reset it. I've been getting the pixelation and screen dimness. It's at the point I can't even take a picture of the pixelation because the screen is so dim, it's almost none existing.
Best Answer09-05-2020 13:54
09-05-2020 13:54
Best Answer01-31-2021 06:26
01-31-2021 06:26
Mine was so much worse than all these photos then it just went blank after trying to reset it several times unsuccessfully. I think it is done for. It was like a bunch of random dots and dashes before it went blank and would not turn on at all.
