03-18-2016 10:17 - last edited on 08-20-2020 18:43 by MatthewFitbit
How can I factory reset my alta?
08-02-2017 08:43
08-02-2017 08:43
08-04-2017 09:53
08-04-2017 09:53
08-06-2017 02:43
08-06-2017 02:43
Display on Fitbit ALTA shows 3/4 charge left, but stops recording. I need to discharge battery to improve its capacity. Please advise.
08-06-2017 17:13
08-06-2017 17:13
Hi, I have a ALTA, and since I gought it, I can configure it, but after 2 mins, when I double tap nothing appears, as it was with no battrery, also, it is not connected again, and in the iphone it says Looking ... with no success. If I plug it into the charger, it turns on, and it is connected again. It says battery full.
Any idea? Thanks in advance
08-06-2017 17:41
08-06-2017 17:41
08-09-2017 02:28
08-09-2017 02:28
08-09-2017 02:56
08-09-2017 02:56
@Sashikiran, you can find the correct contact details for your country by going to contact.fitbit.com
08-12-2017 09:46
08-12-2017 09:46
08-14-2017 19:22
08-14-2017 19:22
This worked better than all the other suggestions! Thanks!
09-10-2017 16:37
09-11-2017 01:38
09-11-2017 01:38
10-10-2017 16:33
10-10-2017 16:33
Reset my altar
11-19-2017 16:57
11-19-2017 16:57
Would someone help me to reset my Fitbit ...date and time are off.
12-10-2017 15:57
12-10-2017 15:57
Sending my back wanted to erase my name etc. Read all the comments seems nothing gets me to the part "erase personal info" anyone had /has same problems & was able to fixed it??
12-10-2017 16:03
12-10-2017 16:03
Hi, @Bing1938, absolutely none of your personal data (name, email) is stored on the Alta device itself, so no one who has access to your Alta will have that info.
12-10-2017 16:06
12-10-2017 16:06
Thank you for your response!!
01-19-2018 08:06
01-19-2018 08:06
So because there is no way to factory reset the Fitibit Alta once you get a new fitbit the alta is just junk because no one else can use it? I just got a new fitbit for Christmas and I was thinking of selling my Alta of giving it to a Family member are you telling me I might as well just throw it away because there is no way for a new user to set it up as their own?
01-20-2018 15:13
01-20-2018 15:13
01-23-2018 04:32
01-23-2018 04:32
I don’t have the original charger. It broke about a year ago. Is there another way
01-23-2018 05:05
01-23-2018 05:05
Hi, @Wendygreiner, I would recommend buying a new charger from Fitbit. It will be listed under accessories in the Fitbit store (link at the top of each page in the forums).
