04-18-2019
05:38
18:17
04-18-2019
05:38
18:17
Dear Support,
Fully Charged Alta not turning on despite restarts. Alta stays on while on charging. But it turns off after few seconds of removing Alta from charging cable. I have done multiple restarts, but this does not resolve the issue.
05-14-2019 11:52
05-14-2019 11:52
Ditto to your experience with tapping keeping the screen alive for a short period of time, same here! Really hoping Fitbit does something about this, fingers crossed!
Best Answer05-15-2019 10:47
05-15-2019 10:47
Hi, there are so many of us facing the same issue. Is it a manufacturing defect or something else? Could someone from the support team help on priority. Thanks
05-15-2019 12:35
05-15-2019 12:35
05-15-2019 21:25
05-15-2019 21:25
I am having the exact same problem. Every time I take it off the charger, it stays on for not even a WHOLE MINUTE!!! Please tell me what to do, other than reset it.
Best Answer05-16-2019 07:00
05-16-2019 07:00
Best Answer05-16-2019 07:03
05-16-2019 07:03
Best Answer05-16-2019 09:08
05-16-2019 09:08
Oh man, so sorry to hear this!! Hoping Fitbit is reading this thread, and will reach out to all of us and rectify this problem. Sounds like it is a structural defect with the Fitbit Alta, and perhaps they would consider replacing our non-functioning Fitbits!!
Best Answer05-16-2019 12:18
05-16-2019 12:18
Hello everyone! I apologize for the delayed response and will be glad to assist you with your Fitbit Alta inquiry.
@dot13, I got in touch with out support team and they informed me that they have already assisted you. Please let me know if you have any questions.
@AnnaP23, thank you for your comments and suggestion. Do you need help to get in touch with support regarding your replacement? You can check our Warranty.
@Laurase, I appreciate your comments regarding your experience with our Support Team.
Welcome to the forums @Crishla, @SunsetRunner, @Piajaniss and @alexandertrevor. Thank you for your comments. I went ahead and created a case on your behalf and a customer support representative will contact you soon. Please check your email.
@AC2905, were you able to resolve your situation with our support team? They told me that you have a case with them.
Thank you for visiting the forums.
Best Answer05-16-2019 12:59
05-16-2019 12:59
Best Answer05-16-2019 13:04
05-16-2019 13:04
Best Answer05-16-2019 16:45
05-16-2019 16:45
Best Answer05-16-2019 16:46
05-16-2019 16:46
Best Answer05-21-2019 10:44
05-21-2019 10:44
Thank you for getting back to us @AnnaP23, @Laurase, and @dot13 . I apologize for the delayed response and will be glad to continue assisting you.
@AnnaP23, was your situation resolved? We're unable to mark cases as urgent.
@Laurase and @dot13 , I understand how you feel and I'm sorry to hear about your situation.
Let me know if you have more questions.
Best Answer06-01-2019 13:33
06-01-2019 13:33
Having the same problem restarted many times, set it up as new device still wont stay on even though fully charged
06-01-2019 14:14
06-01-2019 14:14
06-01-2019 14:47
06-01-2019 14:47
06-01-2019 16:21
06-01-2019 16:21
I am having the same issue. It will not go on or be recognized when i wear it but when its on charger it says battery full and then my app picks it up
06-02-2019 08:50
06-02-2019 08:50
Yeah, not worth it to get a replacement Alta that won't work, or the 50% off another Fitbit. Would be nice if Fitbit just replaced all of the faulty Altas with another Fitbit model, and did not charge the customers a dime!
06-02-2019 11:47
06-02-2019 11:47
Best Answer02-18-2020 13:35
02-18-2020 13:35
I am having the same trouble. The fitbit is fully charged but won't turn on unless it is plugged in. It also won't hold a charge. Clearly the battery needs to be replaced. Oh but wait, you can't replace the batteries in the Alta. Done on purpose so you have to purchase another one.
The Alta was a terribly designed tracker, it never fit my little wrist and I tried several bands. The problem is the tracker is wider than my wrist, NOT an issue with the band. I needed a teen size tracker face that would be about 1/4" to 3/8" shorter.
Look at all the problems people have had with the Alta. It was a total failure. Newer models might have addressed these issues but it doesn't help those who have the first model.
