03-20-2017
06:20
18:17
03-20-2017
06:20
18:17
Hello! So I've had my Alta for about 6 months now. I went to charge it last night and when I put it on this morning it had a full battery and was working fine. After about an hour I went to check my steps and the screen was completely blank and when I tap on the screen it won't show the different screens. I'm not sure if there's just an issue with the battery or if it's completely dead.
04-09-2019 18:39
04-09-2019 18:39
Best Answer04-09-2019 22:34
04-09-2019 22:34
that exact thing happened to mine today and I just put it on charge and it turned back
16:24
17:47
04-10-2019
16:24
17:47
Hi @Carlaa a warm welcome to the Community! Thank you for your feedback and information. I'm Glad to hear that your device started to work again.
@SunsetRunner Than you for your post and information. I've contacted Support about your replacement, and was informed that it should be on it's way to you.
Please let me know if I can assist you further
Best Answer05-09-2019 16:24
05-09-2019 16:24
Where do u find this option on the Fitbit app? I don’t see it.
Best Answer05-13-2019 18:05
05-13-2019 18:05
Welcome to the forums @Babycakes10101 ! I am sorry for the delayed response.
I am glad to assist you with your inquiry. Please let me know what option on the Fitbit app you're looking for? What is the model of your phone?
Looking forward to your response!
Best Answer11-24-2019 14:59
11-24-2019 14:59
Hello my Fitbit Alta is having the same problem and I have tried everything! I don’t know what else I can do!
Best Answer05-04-2020 12:10
05-04-2020 12:10
I had the same problem after not wearing the Alta for over a year. I tried resetting it like the support page says, pressing the button on the charging cable three times, but all it did was vibrate each time I pressed the button. I finally just kept hitting the button, probably a dozen times, then it did a longer vibrate and seemed to reset, and now it works fine.
05-06-2020 11:54
05-06-2020 11:54
Hi I just got my fitbit alta I plugged it in to charge put in the code and this came up ( ! ).now my screen is blank.its not vibrating nothing.its like it's dead.it wont sync with my phone as it keeps saying no device fone.someone please help
Best Answer07-14-2020 09:35
07-14-2020 09:35
My mom got me one yesterday because I keep having blackouts and she wants to track my heat rate. It won’t turn on now 😕 at all. the app said it was fully charged last night but it won’t work whatsoever.
Best Answer07-14-2020 15:15
07-14-2020 15:15
Best Answer07-14-2020 15:31
07-14-2020 15:31
Best Answer07-16-2020 00:20
07-16-2020 00:20
Hi @JuanFitbit I seem to be having the same problem with my Fitbit. A bit sad that this is happening for I was excited about it. Even tried to convince a family member to get one but sure enough its not working now. It’s really frustrating. Please help. I already tried resetting it on my laptop, wall outlet. Searching videos for tips and attempted to do a chat but it wasn’t going threw. What is something you advice to do to fix this problem? Please help.
Best Answer07-23-2020 03:37
07-23-2020 03:37
I am having the same problem - black dead screen. The Alta works only when is attached to the charger. Tried restarting with the button as suggested, but still no results. I am disappointed 😔 with Fitbit.
08-02-2020 13:32
08-02-2020 13:32
Mine's just come back to life after trying someone's suggestion of going to settings, apps, fitbit...force stop.... then switch bluetooth off then on again.... my Alta was able to sync again after a week! No more black screen/face hooray!!
Best Answer08-10-2020 09:10
08-10-2020 09:10
Iam same problem
Best Answer08-10-2020 09:17
08-10-2020 09:17
