04-13-2018
09:04
20:08
04-13-2018
09:04
20:08
My tracker seems to work. Over the course of a couple of months my Fitbit app stop showing me any heart rate data. At first it was just resting heart rates that didn't syncing. I found that to be annoying as I determine how relative healthy I am to my previous self by this measurement. (And all the old data was still there) Then the sleep stages stopped appearing. I thought "alright no big deal... I like the sleep stages but I'll live." But now it won't show me ANY heart rate data new or previous.
I've tried turning AUTO heart rate syncing off and back . I've turn it to just ON too. I changed daily sync to continuous and back. I logged out of my account and back in. I've uninstalled the app entirely and reinstalled it. I've made sure it wasn't the FitBit itself. I charged it to full and I adjusted the band several times different ways.
At this point, I'm at a lose. I'm pretty sure it isn't my Altra HR, but I'm open to any suggestions or if anyone else is having this issue.
04-13-2018 18:33
04-13-2018 18:33
Well you have done all the troubleshooting steps I would suggest Except for restarting your tracker a few times, so give that a go. The tracker may be recording the data but not sending it through to the app so that may fix it. Let us know how you go
Helen | Western Australia
04-15-2018
05:54
06:14
04-15-2018
05:54
06:14
Hi @Wong34. Welcome to the Fitbit Community Forums! 🙂
As @NellyG said, there's not much else that can be advised, however, I also think there's something we can give a try to.
First, make sure to restart your tracker as Nelly said and then, after you've done this, attempt to set up your tracker as a new device. For this, go to the Account section at the top right corner on the Fitbit app and select the option that says "Set up a new device". Follow the on-screen instructions and once you're done, your tracker should be syncing without a problem.
Hope this helps and please, let me know if you need anything else!
04-22-2018 09:03
04-22-2018 09:03
Ok so I removed the tracker on the app and set it up again with settings, prompts and goals. It didn't work. I think it is the application itself.
08-23-2018 16:43
08-23-2018 16:43
I have just updated to 2.77 due to problem syncing steps and calories. Not it is not syncing heart rate or sleep!!! I to have followed the steps without success.
Beyond frustrated!!!
10-08-2018 06:19
10-08-2018 06:19
Same here; it simply doesn't show any heart rate data on the dashboard, old or new. I've gone through the suggested steps and nothing happened.
10-08-2018 08:22
10-08-2018 08:22
My alta hr also is not tracking heart rate. and I have done all those things. I am very disappointed ad I have only had it since May.
10-08-2018 11:09
10-08-2018 11:09
10-08-2018 12:50
10-08-2018 12:50
I have been having similar issues, but I thought to reset the Alta you were supposed to press the button 3 times?
Regardless, I reset mine and I hope it starts tracking my sleep again and stops losing my heart rate.
10-08-2018 13:00
10-08-2018 13:00
10-08-2018 23:46
10-08-2018 23:46
Here is how to restart your tracker
10-09-2018
09:03
10:36
10-09-2018
09:03
10:36
Hi everyone! Good to see you in the Community Forums! 🙂
I'm sorry to hear that some of you are having problems with the heart rate information not showing up.
Now, for those who are having problems with the heart rate not being recorded from your tracker itself, you could try giving it a restart as @NellyG has already suggested.
For those that are not able to see the heart rate tile on the Fitbit app, I'd recommend first to make sure to update the Fitbit app to the latest version available on your app store and then, if you're not able to see the heart rate tile still, scroll all the way to the bottom on your dashboard and tap on Edit. If the heart rate tile is not available, you will have the option to enable it here and after that, it should stay visible.
Hope this helps. Let me know if you need more help with this!
10-17-2018 15:30
10-17-2018 15:30
I have done everything everybody said to do. Still doesn't record heartrate on dashboard. Very disappointed as this is why I bought this tracker.
04-11-2019 23:24
04-11-2019 23:24
Thank you NellyG, the restart worked, now showing my heart rate again.
So pleased!!!
04-12-2019 17:08
04-12-2019 17:08
Having the same trouble. Fitbit driving me crazy
05-23-2019 08:52
05-23-2019 08:52
Mine hasn't tracked since March 5th, dealt with customer support, they had me try all the fixes before finally saying this on the 27th March -
"We apologize for the delayed response. Currently, this a known issue however, we may not be able to provide a fix in the near future. We'll continue to monitor the situation and keep our team informed of its impact. We're sorry for the trouble, and understand this isn't the resolution you're hoping for. Let us know if there's anything else we can do to assist you."
Very frustrating when I purchased the Alta Hr specifically for this feature.
11-28-2019 16:40
11-28-2019 16:40
I have tried everything that anyone suggested. It didn’t do it til I got the news that Google bought Fitbit. Maybe it something they done. I then learn that the Alta Hr is being phased out!! Maybe this is the way to get us Alta people to upgrade to Inspire etc ?????
03-09-2020 09:32
03-09-2020 09:32
I have had this problem twice. The restart/reboot fixes did not work. I then deleted the app, reinstalled and it fixed the problem. No data was lost.
04-22-2020 21:47
04-22-2020 21:47
It does NOT work !!!!!!!!Ι
06-07-2020 11:29
06-07-2020 11:29
Hi,
I'm experiencing similar problems. My tracker shows hr but isn’t showing up in the Exercise graphs, I did find in it the Heart Rate graphs. Hope this helps. I think they need to update app.
