12-11-2019
09:59
20:01
12-11-2019
09:59
20:01
It was correct at 5:30 this morning. The steps seem to be correct and it seems to have synced them with my PC. But now it is 12:48 and it says it is 7:56. Makes no sense. Any thoughts?
12-13-2019 13:53
12-13-2019 13:53
Hello and welcome @beachgeek
I would suggest restarting your Fitbit Alta HR. You will not lose any data doing this.
Here’s how:
😃 Please let me know if this resolves your syncing issue. Keep me posted
12-13-2019 15:17
12-13-2019 15:17
Hi @beachgeek welcome to the Community Forums! Sorry for the delayed reply.
I appreciate the information that was shared in your post. Let me share with you that our Fitbit devices use your mobile device information to display the time with the syncing process, therefore, by simply syncing your Alta HR it should display the correct time, or the one that's on your mobile device. That said, I recommend you to verify if such information is correctly configured on your mobile device.
Also, this may be fixed by updating the time zone setting in your Personal Settings. For step-by-step instructions, please see our help article: How do I change the time on my Fitbit device? and let me know how it goes.
@SunsetRunner Thanks for your helpful post!
Keep me posted.
12-13-2019 15:21
12-13-2019 15:21
Yes, I did that. What happened was all my steps disappeared, reset to zero for the day. About an hour later the time corrected. Sometime after that, maybe another hour, the steps came back. Ahhh!
12-13-2019 15:24
12-13-2019 15:24
I tried all those things before posting and nothing worked. Every smart device in my house had the correct time except for the Fitbit. I have no idea what was going on - or how it got corrected.
12-13-2019 15:35
12-13-2019 15:35
Hello again @beachgeek
I’m happy to see your up and running again. Happy Stepping! 😃 Have an awesome weekend
01-17-2020 14:47
01-17-2020 14:47
Went to Europe and did not take fitbit when I came back wrong time and date.
01-17-2020 14:50
01-17-2020 14:50
How do you sync the fitbit?
01-17-2020 14:51
01-17-2020 14:51
Did not work.
01-27-2020 09:53
