04-02-2017
16:38
18:17
04-02-2017
16:38
18:17
I have read most of the posts on problems with Alta charging and staying charged. I have restarted my device several times, cleaned my charger and Alta battery areas, tried to charge on a computer versus the wall and even tried 2 different Alta chargers to ensure it wasn't the specific charger I was using which was faulty.
I received my Alta as a Mother's Day gift last year, so it's not even 1 year old. I've already had to replace the band because the glue came undone on the part that connects to the actual Fitbit. What is the average lifespan of a Fitbit Alta? I love my Fitbit, but don't think it's a good investment to buy a new one every year. It's a shame because I also received the Fitbit Aria scale as a Christmas present, so I'd like to stay with this brand and would hate to have to switch activity trackers.
Any help would be appreciated! Cheers!
Moderator edit: Updated title for clarity
01-17-2020 05:54
01-17-2020 05:54
01-17-2020 17:26
01-17-2020 17:26
My fitbit alta is now five years old and still working
Susan
01-17-2020 19:01
01-17-2020 19:01
01-19-2020
04:54
04:06
JuanJoFitbit
01-19-2020
04:54
04:06
JuanJoFitbit
I have had my Fitbit Alta since mid-2016, so 3.5 years. It still functions well but sometimes runs out of battery rather quickly or does not record my sleep. So I ordered a new Fitbit Inspire HR and it was even worse at recording my sleep, so I suspect it is a problem with the system at Fitbit, maybe not with my device. The battery drain is inconsistent and might be related to the increasing number of texts I am receiving. At any rate, it seems difficult to determine if a new device provides a solution. I do wish Fitbit would tell u what to expect as an average lifespan of these devices.
Just read your post. Fitbit Alta still going strong? Is it tracking your sleep consistently? Bought mine around the same time and it is starting to have problems but very inconsistently.
Did you upgrade? If so are you happy? I tried the Inspire HR but found it harder to read in some ways. Wouldn't track my. sleep consistently so I returned it. Now my Alta is doing the same thing. Maybe it's a Fitbit system problem and not my device.
Moderator edit: merged replies
01-19-2020 06:19
01-19-2020 06:19
Hi...I upgraded to the charge 3 and hope this one lasts longer. It's so easy to use I am happy with it.😊
01-19-2020 14:16
01-19-2020 14:16
01-19-2020 16:02
01-19-2020 16:02
01-19-2020 16:22
01-19-2020 16:22
how old was your fitbit Alta when it died
Susan
01-20-2020 02:20
01-20-2020 02:20
18mths🥴 happy with my charge 3 so far.
01-20-2020 03:16
01-20-2020 03:16
I've had my Alta for nearly four years now and it's still working like a dream never had any issues whatsoever. I wore my Alta in the shower a few times to check if was waterproof,and I now wear it swimming and can honeslty say it is fully waterproof "oh happy days 🙂 "
01-20-2020
14:26
04:08
JuanJoFitbit
01-20-2020
14:26
04:08
JuanJoFitbit
Whitesox10, if this question is directed to me, I had it just under 18 months.
MiniMo1, Alta and Alta HR are not waterproof according to the Fitbit specs on their website. There was even a response from a Fitbit rep stating the same. Another person stated his is, but it seems he bought it from somewhere other than Fitbit and the Alta had been modified to make it so, which of course took it out of warranty. Although after four years, that doesn't affect you anyway, does it?
So happy to hear you're still enjoying your Alta after all this time!
Moderator edit: merged reply
01-20-2020 15:57
01-20-2020 15:57
Why is fit bit Alta and fit bit Alta is not waterproof
Susan
01-21-2020 08:01
01-21-2020 08:01
01-21-2020 15:03
01-21-2020 15:03
Hi, I bought my Fitbit Alta at Gatwick airport before going on holiday, completely legit, and of course tax free. Like I say I'm still using it it daily and swimming with it on too. Best purchase ever in my opinion 🙂
01-21-2020
16:35
04:10
JuanJoFitbit
01-21-2020
16:35
04:10
JuanJoFitbit
Got my fit bit Alta from Costco
I wish my fitbit alta was waterproof
Susan
02-22-2020 08:49
02-22-2020 08:49
I have had my alta for about 4 years and just recently it does within 2 days and will no longer sync at all. I purchased an Inspire HR, but haven't started using it yet. What are the issues you found with the Inspire?
02-24-2020 11:20
02-24-2020 11:20
No issues with my fitbit alta at all yet
Susan
04-19-2020 13:58
04-19-2020 13:58
Hi,
My Fitbit Alta lasted about 3 years and 9 months. The last 6 months were a bit unpredictable with it resetting and needing charged more often.
It now needs connected daily and then on lasts a few hours.
Almost 4 years is not too bad and quite fancy the Inspire HR as a replacement.
04-19-2020 14:04
04-19-2020 14:04
Had fitbit alta for 5 years it is my first fitbit
Susan
04-19-2020 14:21
04-19-2020 14:21
Went through lots of bands as the plastic part that clips onto the tracker kept breaking. Found unofficial Bands from EBay cheaper and more robust.
