03-30-2017
22:10
18:17
03-30-2017
22:10
18:17
I've lost my Fitbit I've looked high m low Help! Thought I lost it at work but looks like I went home with it.. tried yo sync n nothing suggestions please... Thank you
Moderator edit: edited title for clarity
01-08-2020 23:20
01-08-2020 23:20
Which apps did you use that worked good to find your lost Fit Bit? I lost my Fit Bit somewhere in the house on New Year’s Day and I had just put it on after charging it. It was logging my steps up until 5:30 pm then suddenly stopped. I assume that is the time it fell off. I need to try and find it before the battery dies but not sure which app to buy. I ave tried a couple of free ones but feel like I am on an Easter Egg hunt with a drunk bunny! Your help would be greatly appreciated.
Best Answer01-09-2020 20:49
01-09-2020 20:49
Hi @Sunshine61 your Fitbit battery is probably close to dead, if not completely dead by now. Are you able to sync? When you're within 25 feet of it, it should sync. If possible, set up a silent alarm and then listen for it to vibrate. If it is near paper or something that rattles, you'd be able to hear it.
Best Answer01-10-2020 10:42
01-10-2020 10:42
