03-11-2016
08:33
21:34
EstuardoFitbit
03-11-2016
08:33
21:34
EstuardoFitbit
Hi everyone,
I just received my Alta after pre-ordering. I am currently in the process of setting it up using the android app. Right now it is not seeing it while my bluetooth is on. The first screen says Power Up, and it is searching for it but does not find it. After that, the Not Working? screen comes up, and you have the option to try again. After selecting try again, It then says Bluetooh Issues. This is where you can restart Bluetooth, which I've done multiple times already. I know my bluetooth works on my phone because I have it setup to work with my headphones with no problems. I have it securely connected to the USB pin connecter which is then connected to my PC. It is charging so I know there is connectivity. I've restarted my phone a few times, but to no avail. I never had any problem connecting with my HR. Has anyone else experienced this with the Alta, does anyone know of anything that I could do to fix this issue.
Thanks!
Moderator edit: edited title for clarity
06-18-2016 05:06
06-18-2016 05:06
Same here. No response from Fitbit.
Best Answer06-19-2016 17:49
06-19-2016 17:49
Best Answer06-20-2016 17:35
06-20-2016 17:35
i have had the same issues. how did you get yours to work?
Best Answer06-20-2016 17:36
06-20-2016 17:36
have done this multiple times and now i cannot get past the screen where it asks to match the four numbers on the fitbit. any suggestions?
Best Answer06-20-2016 18:07
06-20-2016 18:07
Best Answer06-20-2016 18:10
06-20-2016 18:10
Best Answer06-21-2016 14:11
06-21-2016 14:11
Best Answer07-02-2016 10:39
07-02-2016 10:39
Thanks! Your tip worked!!!
Best Answer07-02-2016 10:42
07-02-2016 10:42
Great!
Best Answer07-02-2016 19:51
07-02-2016 19:51
Best Answer07-24-2016 14:59
07-24-2016 14:59
yours was the only tip that worked! How silly all this technology can be lol.
@hollyaw24 wrote:I do not have one, but are you replacing an existing fitbit? I know that when I tried to pair my new Charge HR near my sister when she was wearing hers, it wouldn't pair. I had to wait until she went home 🙂
That's my only tip for you.
How do you like the look and fit of the device?
Good luck!
Best Answer07-25-2016 03:15
07-25-2016 03:15
Great!
Best Answer08-12-2016 15:24
08-12-2016 15:24
You almost got me there now there is a error in syncing.
Best Answer08-12-2016 23:37
08-12-2016 23:37
@Judy1946 wrote:
Can I change my Charge HR account to an Alta account
@Judy1946 you don't change your account, the account is about you, not your tracker.
There are two choices you have, add the tracker as a second device or add the tracker as a replacement device.
As a second device you may choose which one to wear today, as a replacement the HR will be unusable until it is setup to an account, yours or somebody elses.
Best Answer08-14-2016 06:32
08-14-2016 06:32
Hi everyone,
My wife's replacement Alta arrived 2 days ago and we still can't get it working. It seems to have charged because it is recognized during the set up process, and bluetooth recognizes it, but I can't get the number to "pair" it because nothing displays on the screen of the Alta. I have tried restarting over 10 times but nothing on the display.
Any ideas or suggestions?
Thanks
Best Answer09-17-2016 05:38 - edited 11-04-2016 19:01
worthless
09-17-2016 05:58 - edited 11-04-2016 19:00
get me off this blog
Best Answer09-17-2016 07:41
09-17-2016 07:41
Best Answer09-24-2016 08:16
09-24-2016 08:16
Best Answer09-24-2016 19:55
09-24-2016 19:55
