03-15-2016
		19:44
		18:43
		03-15-2016
		19:44
		18:43
01-05-2018 21:04
01-05-2018 21:04
Mine is doing the same thing with the logo and random numbers. How did you fix it???
 Best Answer01-05-2018 22:15
01-05-2018 22:15
 Best Answer01-06-2018 03:08
01-06-2018 03:08
I’m replacing it it’s coming in the mail contect Fitbit how old is you’re Fitbit
 Best Answer01-06-2018 06:50
01-06-2018 06:50
i'm finally getting a new charger to see if that's the issue
 Best Answer01-06-2018 06:51
01-06-2018 06:51
the "random numbers" is the sync code --- your fit bit is trying to reset.... it... have it close to your devise when its trying to reset.
 Best Answer01-06-2018 11:33
01-06-2018 11:33
 Best Answer01-12-2018 08:37
01-12-2018 08:37
My Alta is brand new and fully charged. I was not able to fully set up my profile/account. The message on my Alta says www.fitbit.com/setup. Can you help me?
 Best Answer01-12-2018 21:24
01-12-2018 21:24
@CindyFitbit wrote:A warm welcome to the Community @Alicia22! That's weird! First, please restart your tracker by following this instructions step by step:
1. Plug your charging cable into a USB port on your computer or any USB power adapter.
2. Insert the other end of the cable into the port on the back of your Fitbit Alta. Your Alta will begin charging.
3. Press the button on your charging cable three times within eight seconds, briefly pausing between presses. The button is on the end of the charging cable that is plugged into your computer.
4. Eight seconds after the first button press, you'll see the Fitbit logo on the screen. This means Alta is restarting.
5. After you see the logo you can unplug your tracker from the charging cable.
After that, please make sure of charging it fully.
Let me know how it goes!
Moderator edit: link update
What button? I have none.
 Best Answer01-13-2018 06:29
01-13-2018 06:29
you have to do the set up from a computer or mobile device browser... go to that address www.fitbit.com/setup
 Best Answer01-16-2018 06:09
01-16-2018 06:09
tried the re-start method described - three taps on the charger. the fitbit logo does come up but the time is not resetting. Any other suggestions for correcting the time?
 Best Answer01-16-2018 12:23
01-16-2018 12:23
It didnt work for me
 Best Answer02-12-2018 20:15
02-12-2018 20:15
We have 2 Fitbit Alta HR (1 month old). My son's had a black screen, green lights on the underside stay lit all the time, vibrates when connecting to charger and when pressing the reset buttons. But I have tried reset as described (at least 8 times between son and me).....no response. Other advice?
 Best Answer02-12-2018 22:01
02-12-2018 22:01
 Best Answer03-05-2018 18:37
03-05-2018 18:37
Mine is doing the same thing. I was able to restart by pushing the little button 3 times and the battery symbol shows up with an ! in it which is not normal. Doesn't appear to be charging either. Mine is barely a year old and worked fine yesterday before the so called update.
 Best Answer03-05-2018 19:22
03-05-2018 19:22
 Best Answer03-07-2018 06:46
03-07-2018 06:46
Thank you very much for giving the instructions. When you go to FAQ the question is there but no instructions. Again thank you.
 Best Answer03-09-2018 23:34
03-09-2018 23:34
I have tried this solution twice. Although the fitbit has shown restart symbol my history / dashboard still indicate that I haven't synched since Monday morning
 Best Answer03-12-2018 15:54
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              03-12-2018 15:54
Hey everyone! Thanks for the details you've mentioned, I would like to help you sorting this out. Please confirm you've performed a restart and make sure you're properly charging it, if the screen isn't working.
If after this, your Alta's screen is still not turning on let me know so I can share your post with our Support team.
Hope this helps! Keep me posted.
03-22-2018 11:50
03-22-2018 11:50
Just read this but what button on the charging cable?
 Best Answer03-22-2018 18:25
03-22-2018 18:25
