05-24-2016 15:05 - last edited on 08-20-2020 18:17 by MatthewFitbit
12-20-2017 09:37
12-20-2017 09:37
I’m in the same boat. Help please!
12-20-2017 09:41
12-20-2017 09:41
@r2lyons I was having the same issue. Turned Bluetooth off and then back on on my phone and it worked right away!! Hope this helps!
12-26-2017 18:46
12-26-2017 18:46
How do I turn on my fit bit hr
12-26-2017 21:16
12-26-2017 21:16
I don't seem to have a button on my charging cable that I can see !!!?????
12-26-2017 21:18
12-26-2017 21:18
Grrr silly me I found it!!! Ty
12-30-2017 10:08
12-30-2017 10:08
Charging seems to be working but will not connect to the phone s8
12-30-2017 10:10
12-30-2017 10:10
Yes charging battery sign
But how do we turn it on
12-30-2017 10:12
12-30-2017 10:12
OK
Did that
Now What?
12-30-2017 20:53
12-30-2017 20:53
I have been charging my new Fitbi Alta for the first time for over 2 hours and the only thing on the screen is an explation mark. Is this normal?
12-31-2017 01:38
12-31-2017 01:38
01-04-2018 18:32 - edited 01-04-2018 18:33
When you're trying to set up your Alta on the app for the first time, make sure you're choosing the right Alta. I spent an hour trying to set up the Alta HR when I bought the Alta. As soon as I picked the right model it was perfect.
Dumb solution, but I can't be the only one that did that.
01-05-2018 15:08
01-05-2018 15:08
01-08-2018 13:37
01-08-2018 13:37
My Fitbit alta has now been charging for 6+ hours but all I can get on the display when I tap it is Fitbit.com/setup. I can't get it to do anything else. Am I doing something wrong.
help, this is driving me crazy.
01-09-2018 13:57
01-09-2018 13:57
You can return to Amazon.
01-27-2018 10:25
01-27-2018 10:25
Bit is fully charged. Pres yhe button three times. Its paired with my phone. Why can't i set it up? Only get to the search screen....
01-27-2018 13:01
01-27-2018 13:01
I am having the same problem. Only difference is that mine had enough charge to register but is now dead. Following you to see if you have a resolution
02-02-2018 21:18
02-02-2018 21:18
I was able to sync after power cycling my phone. This is in addition to restarting the fitbit alta hr as per previous posts, touching the screen to turn it on, and toggling bluetooth off and on. The power cycling was key.
02-04-2018 09:55
02-04-2018 09:55
then what?
02-06-2018 16:18
02-06-2018 16:18
How do I turn on my Fitbit Alta?
02-15-2018 11:30
02-15-2018 11:30
That won't work for me!
