05-24-2016
15:05
18:17
05-24-2016
15:05
18:17
12-27-2018 21:58
12-27-2018 21:58
I am not able to tap my fitbit to open and went through steps for reset. Talked with Dean at customer support and a link was sent to get a replacement. I cannot open the linl because it asks for a fitbit password and I do not have one. HELP
12-28-2018
21:15
09:26
MarcelBK
12-28-2018
21:15
09:26
MarcelBK
I think when you go into fitbit setup on your phone you set up a name and password.
I was frustrated too cause I couldn't tell if it was charging or setting up. First I set up my account on fitbit set up.com and downloaded the app. It said it saw the tracker but the bluetooth didn't sync. After plugging it into a wall plug and not being sure it charged I plugged it into the computer port after i read that it was supposed to be plugged into a low charge USB and let it charge then I did what they suggested here . Tapped the button - who knew it was there? - at the end of the USB plug and voila I got the pass #.
After that it said keep the fitbit close to the phone to update.
After 8 minutes the update was done and it now works.
They really need to include start up info in the box. It is frustrating to have to screw around with a device for an hour when it could have had step by step instructions that would make life easier
Update:
I found moving the charger thing a bit helped it to connect on the back
Update:
Move the charger piece on the back till you see the battery symbol. Once it is charged push the button on the USB end of the charger 3x waiting a few seconds between each depression.
That is how I finally got it started.
Update:
Sylvia check out my answer at the end of this thread
Update:
Denise does yours work?
I got mine to work. Check out my answer at the end of this thread
12-31-2018 17:00
12-31-2018 17:00
where is the I icon located on my watch! all I see is fitbit.com/setup
Best Answer01-01-2019 06:37
01-01-2019 06:37
I had a similar problem, then realised I'd set up the app for the Alta HR, rather than the Alta. Easy mistake to make, so might be worth checking.
Hope this helps!
Best Answer01-01-2019 14:30
01-01-2019 14:30
Best Answer01-17-2019 09:48 - edited 01-17-2019 09:49
It is nice to see that you visit the Community @Denisetrying, @RhondaRJ, @BLambertz75, @Jojo54, @cbrenton and @Jack100! I could read that some of you have issues to charge the Alta tracker. Please try the following tips to resolve the charging issues.
The contacts on the tracker or charging cable may be dirty. Clean the charging contacts on the back of the tracker, and the pins on the charging cable so that they are still bronze or gold in color. Proceed like this:
Others in this thread seem to have difficulties with the set up. Please note the requirements and troubleshooting steps of this Help-site article.
If you tried everything and it still not work, please post again.
Have a nice day! ![]()
Hat dir mein Beitrag geholfen dann markier ihn als Lösung und gib mir Kudos![]()
Best Answer02-06-2019 12:18
02-06-2019 12:18
How do I start
Best Answer02-06-2019 13:04
02-06-2019 13:04
Best Answer02-10-2019 10:46
02-10-2019 10:46
Where is the button on the charging cable? Near the USB connector or the other end?
Best Answer02-23-2019 11:36
02-23-2019 11:36
I have tried this method several time and it still won’t turn on . After the 3 presses it shows the Fitbit sign and the software version then the /setup
a present that won’t work please
help
02-23-2019 13:42
02-23-2019 13:42
Best Answer03-11-2019 08:46
03-11-2019 08:46
The tutorials show a dongo and and say to push button charging cable. I have neither. How can I tell if unit is charging?
Best Answer07-10-2019 05:17
07-10-2019 05:17
I have tried everything to get my brand new Alta to charge. I was able to set it up and sync, but it won’t charge.now that I have tried to press the button to reset, nothing comes on the screen and it will not sync now. Help!!
Best Answer07-12-2019 13:15
07-12-2019 13:15
I have it on the charger but can't figure out how to turn it on. This site says to press the button on the charger three times. There's no button on my charger. Help!
Best Answer09-19-2019 19:28
09-19-2019 19:28
I am trying to connect an Alta HR to a computer or phone. I've tried a Chromebook, MacBook and iPhone and still no luck. It is unable to find the device and connect to it. Help!
Best Answer10-09-2019 03:28
10-09-2019 03:28
I've had my fitbit alta for sometime but the wrist band for it broke and i just recently replaced it. I would say i havent used my Alta in almost a year. I plugged it in and its charged but when i tap the screen or turn my wrist towards me it wont turn on. Also whenever i sync my phone to it, it has a red circle with an exclamation mark in it.
Best Answer11-20-2019 02:16
11-20-2019 02:16
My Fitbit not connected
Best Answer11-21-2019 15:28
11-21-2019 15:28
Hmm... Dont know bout that
Best Answer11-29-2019 22:50
11-29-2019 22:50
Charged but Bluetooth will not connect
12-18-2019 11:20
12-18-2019 11:20
I’m having this issue now how did you resolve it?
