03-14-2016 13:19 - edited 08-20-2020 18:43
One of the trickiest parts of getting started with a brand-new wristband tracker is simply learning how to get it clasped properly. The following post can help you with that!
How do I clasp my Alta wristband more easily?
We're confident that you'll be able to get your alta clasped with just a little practice. Don't be discouraged if it's difficult at first - it definitely gets easier over time!
How do I change my Alta wristband?
Fitbit Alta's wristband is detachable from the top and bottom of the tracker, so that you can replace it with accessory bands of different color or material. For help with detaching your Alta's wristband, check the steps in this help article, or watch the video below.
03-19-2016 09:04
03-19-2016 09:04
For those of us with no husband AND arthiritis, fastening the Alta on our wrist is impossible! Especially the 'pinch' method.
The solution for me will be the stainless steel bracelet IF they ever release it! Any word on when that will happen? I tried to order it in early February when I preordered my Alta and I check the web site every day -all I see is the "notify me" button!
03-19-2016 10:55
03-19-2016 10:55
03-19-2016 14:08
03-19-2016 14:08
Never fear, there is a solution. I couldn't snap it and neither could my hubby. So while it was off my wrist, I sat and snapped and unsnapped a dozen times (in the 2 holes I needed) and now I can get it on by myself. It is just difficult until you have done this to loosen up the holes.
03-19-2016 16:15
03-19-2016 16:15
Did that open the holes too much so that it tends to fall off?
03-19-2016 17:42
03-19-2016 17:42
Just adding my complaint to the others. The band seems like a really big miss on an otherwise nice product. Cynically, I'd say it is to push their new option (NEW BANDS!). Thanks for the olive oil suggestions.
03-19-2016 19:04
03-19-2016 19:04
03-20-2016 07:23
03-20-2016 07:23
I have done this, but also have arthritic fingers, and just can't close the clasp. I have found that if I disconnect the wrist band at the tracker I can get it on and off, but it's looser than I like. I'll give it another few days and then decide if its worth the trouble.
03-20-2016 07:25
03-20-2016 07:25
03-20-2016 07:43
03-20-2016 07:43
03-20-2016 07:57
03-20-2016 07:57
03-20-2016 08:29
03-20-2016 08:29
Seriously? How much more would it have added to the cost to have put a "user friendly" band on it...one with a clasp? I am struggling every day with this thing. I have some arthritis in my fingers and this band is a killer.
03-20-2016 08:30
03-20-2016 08:30
I have found the key to the tapping, is not to tap with the nail part of your finger, but to do a flat finger pound. It has to be done just right or it won't turn on. Keep practicing but I agree. This is annoying as hell. I'd rather have little buttons.
03-20-2016 08:49
03-20-2016 08:49
I agree - and you also need to tap where the band and tracker meet, not in the center of the tracker. Works much better. I wish they would have stated that in the instructions though. I had to find it out on this community forum when a moderator clarified it.
03-20-2016 09:05
03-20-2016 09:05
03-20-2016 11:01
03-20-2016 11:01
I had the same problem and called the Fitbit help desk to 'whine' that it sucks. Not too much they could do to help but felt better to issue my complaint. So I stayed with it and finally figured it out (somewhat) this: on your wrist, the same side as your thumb right below the hand, you'll find a small bone. Right below that, I place the holes I want to use and push down on the clasp until I finally 'feel' it connect . I have small wrists and don't like the band to slide up and down which keeps me from being able to slide my fingers beneath the band. By doing it this way, I won't have to deal with a bigger band plus it doesn't hurt and, also important is it works if you don't have anyone to help. Just say'n.... those holes do get easier to connect with use.
03-20-2016 12:21 - edited 03-20-2016 12:23
I will try this matthewfitbit but still you guys need to think of people with arthritis. I have terrible pain in my right hand so I am hoping that if I do it and undo it a bunch it will get easier. But wow. Maybe if this is interchangeable the fitbit people need to make a band with a clasp for people with arthritis. Thank you.
03-20-2016 12:31
03-20-2016 12:31
03-20-2016 22:47
03-20-2016 22:47
I had the same complaints: struggling to get it on and then having to really knock the top to get it to register. But, I used a pair of needle nose pliers (anything that is tapered will work) to very gently stretch the holes on the band (you shouldn't be able to see any difference and it should still be secure) and now it is easy to get on and much more responsive. It only took a few seconds and it made a HUGE difference.
03-21-2016 05:43
03-21-2016 05:43
FWIW, I've always thought that instead of wearing it in the shower (what are you going to track?), that's a good time to put it on the charger.
...my $.02
03-21-2016 05:49
03-21-2016 05:49
@SunsetRunner wrote:
I have mine on as directed-charging prongs on top outside of wrist, biut the band clasp seems to be going the opposite direction of the band clasp in the illustrations above. Is the band on backwards from the factory? I just got it yesterday and love it. The clasping does get easier!
If it seems backwords for you, you can always switch the bands to the other sides of the main unit. Hpe this helps!
