07-14-2016 06:59 - last edited on 08-20-2020 18:17 by MatthewFitbit
01-11-2018 11:48
01-11-2018 11:48
I’ve tried everything but there doesn’t seem to be a solid solution that’s working. Did anyone manage to get theirs to work? If so, how?
thanks
01-12-2018 20:41
01-12-2018 20:41
Omg! your so right!, that worked, thank you
01-12-2018 21:54
01-12-2018 21:54
@MaginB wrote:Welcome to the Community @robynleighton! I hope you're doing great!
Let me help you out, What happened to your tracker? what type of issue are you experiencing? in order to restart it double check you're following these steps:
1. Plug your charging cable into a USB port on your computer or any USB power adapter.
2. Insert the other end of the cable into the port on the back of your Fitbit Alta. Your Alta will begin charging.
3. Press the button on your charging cable three times within eight seconds, briefly pausing between presses. The button is on the end of the charging cable that is plugged into your computer.
4. Eight seconds after the first button press, you'll see the Fitbit logo on the screen. This means Alta is restarting.
5. After you see the logo you can unplug your tracker from the charging cable.
Catch you later!
Is restarting suppose to zero everything out? Because mine didn't. Everything was the same after it was done.
01-17-2018 17:14
01-17-2018 17:14
I took the advice of pressing button 3 times in 2 seconds- worked!!!!! Reset...after days of frustration. Thanks
01-24-2018 10:36
01-24-2018 10:36
What do u mean clear contacts??
03-08-2018 18:18
03-08-2018 18:18
i have tried everything and mine wont reset either. I have to charge it every night. Anyone with success can you please tell me how you got it to reset ?
03-09-2018 02:46
03-09-2018 02:46
I am having similar problems, cant restart, cant sync. It seems to me that so many people are having this problem that the product has an inherent fault and should be returned as faulty. I am going to give it one more day and then its going back. Still only 6 months old.
03-09-2018 04:20 - last edited on 11-07-2019 14:01 by LiliyaFitbit
I sent an email to fit bit and they sent me a new one as it was in warranty they will check there records
Thanks
Sent from my Samsung Galaxy smartphone.
03-09-2018 04:29
03-09-2018 04:29
thank you
03-22-2018 16:16
03-22-2018 16:16
Thank you this worked for me as well!
04-19-2018 21:25
04-19-2018 21:25
This is happening to mine
How did you resolve 😁
04-19-2018 21:29
04-19-2018 21:29
04-19-2018 21:38
04-19-2018 21:38
04-19-2018 22:15 - last edited on 11-07-2019 14:01 by LiliyaFitbit
I sent fitbit customer service a message, they looked up my fit bit and it was in warrenty and send me a new one
Kind Regards,
[https://s3.amazonaws.com/images.wisestamp.com/widgets/green_32.png] Please consider your environmental responsibility. Before printing this e-mail message, ask yourself whether you really need a hard copy.
04-19-2018 22:18
04-19-2018 22:18
04-19-2018 22:26 - last edited on 11-07-2019 14:02 by LiliyaFitbit
I'm not sure sorry
Kind Regards,
04-22-2018 18:23 - last edited on 11-07-2019 14:02 by LiliyaFitbit
I bought a new one....
iPhone
04-22-2018 22:21
04-22-2018 22:21
04-27-2018 11:52
04-27-2018 11:52
Hi everyone and welcome to the new users!
Thanks for bringing this to our attention, I can see a few topics mentioned here so I would like to cover as much as possible, please take a look at the steps provided here to resolve any trouble with the syncing process. If you're stats are not resetting at midnight the first step to attempt is the restart to your Alta, if you're still having trouble you can also check that you're running the correct timezone take a look at these instructions.
If by any chance you're still having trouble please let me know so I can give you the next steps!
05-14-2018 20:30
05-14-2018 20:30
Your response was not helpful. The original poster stated she attempted to restart according to the instructions. You later repeated the exact same thing stated.
