@Peacefullyfitbi Welcome to the Fitbit Community! I hope you're doing well!
I will assist you with your Charge 3 not charging. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
