11-18-2024 02:20
11-18-2024 02:20
Since latest update when I enter my weight it will not accept stones. From setting changed to kg that works. Set back to stones only option to input is pounds when entering new weight. Same on both android devices i use tried logging out and in, reset all devices too no change
12-08-2024 14:43
12-08-2024 14:43
Thank you for escalating this! I have the same issue and its really annoying. Please can this be resolved as soon as possible. Thank you so much.
12-08-2024 23:05
12-08-2024 23:05
Best Answer12-09-2024 00:46
12-09-2024 00:46
Agree it's been passed up chain at least 3 times now let's hope it's resolved soon
Best Answer12-09-2024 03:52
12-09-2024 03:52
@Aligrace Yes, this is known bug in the Android version of the Fitbit app.
Laurie | Maryland
12-11-2024 05:51
12-11-2024 05:51
Hi everyone, and welcome to the new members.
Thanks for your continued reports. I understand how frustrating this has been for you and appreciate your feedback. As I mentioned before, this issue has been escalated to our team and they're currently working to get it fixed soon.
Once we have more information to share, rest assured that we'll update this thread.
12-11-2024 16:34 - edited 12-13-2024 09:33
Thanks @SulkingSausage 👍👍 for mentioning in your post how to get back to the original weight entry screens (it was on page 3 of 5 when I posted this). I don't know why they felt it necessary to muck about with something that had nothing wrong with it, perhaps it wasn't quite pretty enough for Google? I've made a screenshot of your response in case I need a prompt in the future since I doubt they'll fix it this side of Christmas!
Best Answer12-12-2024 00:16
12-12-2024 00:16
how did you do it? let us all know
Best Answer12-12-2024 03:00
12-12-2024 03:00
Best Answer12-12-2024 03:16
12-12-2024 03:16
12-12-2024 04:09
12-12-2024 04:09
12-12-2024
16:43
10:18
AndreaFitbit
12-12-2024
16:43
10:18
AndreaFitbit
@gillianlesleywh I did what Sulking Sausage said in her post on page 3. Open the weight section, click the 3 dots at the top right, then click 'Manage Data'. About halfway down the page (depending on your phone's text size) you'll see "REVIEW YOUR DATA" in teal green caps. That takes you to the old weight screen where you can just click the + button to add your weight in st/lb. Only downside is you can't add or change the date, it will auto add those at the time of entry and you can't change it in the new screen because it will empty the weight field. The bug is obviously some kind of broken relationship between the old and new weight screen so find a workaround that you can live with as it may take them a while to work out who did what!😅
Great idea @Trophy3 . You could even go one better and add a Fitbit 'quick access' widget to log weight. Then you'll just have to tap that to enter your weight in st/😁
Best Answer12-12-2024 20:35
12-12-2024 20:35
Thanks so much for this, it worked, at least it's something until they hopefully fix the problem. 😏
Best Answer12-13-2024 08:33
12-13-2024 08:33
Hi everyone, and a warm welcome to our new members.
Thanks for your continued reports, and sharing a workaround on this issue.
As I mentioned in my previous post, our team is further investigating and so they can continue working on it, we'd appreciate your feedback on your preferred method for entering your weight in stones. To gather this information, please complete this form with the required information.
Once again, thank you for your patience. I will keep you posted on any update.
12-14-2024 06:09
12-14-2024 06:09
Thanks for this SulkingSausage. Regarding the first rule of applications support , "If it ain't broke don't fix it!", what often happens when one company buys a competitor is that they decide they've got their own Apps Support team so don't need the competitor's team. End result is that they loose umpteen staff-years of application knowledge and a fix that could have been fixed overnight,takes months. I've only experienced this problem since I moved from a Pixel 4a running Android 13 to a Pixel 8a running Android 15, so I expect it will be a case of waiting for the next update.
Best Answer12-16-2024 02:01
12-16-2024 02:01
this is a pain, I always entered weight by opening the app and then hitting the + symbol; but I find that if you press and hold app icon on home screen then you get an option to add weight there, which still lets you input in stone & lbs
hope that helps
12-16-2024 11:34
12-16-2024 11:34
12-17-2024 00:15
12-17-2024 00:15
Never tried that before. Well done you!
12-17-2024 05:45
12-17-2024 05:45
12-18-2024 09:11
12-18-2024 09:11
Hi everyone, and welcome to our new community members.
I appreciate you for the time you took to take the survey. I wanted to let you know that our team received your responses and because we have the necessary information, the form has been closed. They'll continue working to bring a fix soon, and rest assured that I'll keep you posted in this thread.
For now, please keep the Fitbit app updated and use the workaround shared by @Trophy3 to log your weight.
12-18-2024 20:41
12-18-2024 20:41
It's a pretty simple fix just un do the update before the 1st week of December? Honestly the app is awful now the weight thing and layout, the time takes to refresh and update. I don't see why it's taking so long, and we should be happy with a workaround?
