11-18-2024 02:20
11-18-2024 02:20
Since latest update when I enter my weight it will not accept stones. From setting changed to kg that works. Set back to stones only option to input is pounds when entering new weight. Same on both android devices i use tried logging out and in, reset all devices too no change
11-28-2024 08:16
11-28-2024 08:16
Best Answer11-29-2024 01:12
11-29-2024 01:12
Thanks will stop trying to fix and hope they do not update and create further bugs.
11-29-2024 02:22
11-29-2024 02:22
Same here. Is this a bug, or another example of Google removing functionality if they think the number of users affected is too small to make a fuss ?
When my fitbit expires, I will definitely be buying a different brand
11-29-2024 04:03
11-29-2024 04:03
Hi,
Any idea why the ability to enter/log weight in Stone + decimal pounds (ie pound + fraction of a pound eg:3.7) has been removed pls?
Or is this configurable shoewhere.
Now has to be in decimal pounds only.
My scales only shows Stones + Decimal Pounds - so now a calculation is required just to enter my weight.
11-29-2024 04:22
11-29-2024 04:22
Fb says its a bug others on Google have same problem, if it is a bug on past experience fb will wait ages before sorting. Not very good on customer relations
11-29-2024 06:08
11-29-2024 06:08
Best Answer11-29-2024 06:32
11-29-2024 06:32
11-29-2024 06:38
11-29-2024 06:38
On the android device you are using, you will have an app icon for fitbit. If you don't, you'll need to download and install it. Then long-press on that icon. A set of quick access options will appear - one will be log weight.
This may be dependent on the version of Android you are using however. 😞
11-29-2024 07:48
11-29-2024 07:48
Hello @bossredman and welcome to the Community. The good news is that you don’t have a firmware problem. There is a new bug in the Fitbit app affecting users who weigh in stone. Fitbit is aware, but there is no timeframe for a fix.
Laurie | Maryland
11-29-2024 07:53
11-29-2024 07:53
11-29-2024 12:56
11-29-2024 12:56
Mine is doing the same. It's so annoying. I have to work out the pounds before I enter the amount.
Also, it's showing me as 10 stone 14. You can't be 10 stone 14.....that's 11 stone! 🙄
11-30-2024 01:44
11-30-2024 01:44
I'm having the same issue. It's so annoying. Really going off fit bits now and trying to get real help is a no go
12-01-2024 05:26
12-01-2024 05:26
Same issue, hopefully the bug will be addressed soon.
Best Answer12-01-2024 13:31
12-01-2024 13:31
Saying it "only" affects users who weigh in stones is trivialising it.
We use stones in the UK. Are you saying the UK market is not important enough to implement a fix?
12-02-2024 00:00
12-02-2024 00:00
yes me too and my aria scale is no longer syncing with it - I can see the page refreshes as it trys to record the weight but cant do it
12-02-2024 02:35
12-02-2024 02:35
I am around about the 5 stone loss mark but I can't tell if I've hit it due to recent update. All I can see is average weight. No starting weight or total loss. It's so frustrating! I'm truly gutted as I usually screenshot my overall loss to share success with family and I've no idea what I've lost or where I'm at.
12-02-2024 02:56
12-02-2024 02:56
12-04-2024 10:13
12-04-2024 10:13
Hi everyone, and welcome to our new members!
Thanks for bringing this to our attention, and taking the time to troubleshoot the Fitbit app. I've gone ahead and escalated your information to our team so they can investigate, as well as identify a solution as soon as possible.
I'm sorry for the inconvenience this has caused, and I appreciate your feedback. Please know this thread will be updated as soon as we have more information available.
12-04-2024 10:37
12-04-2024 10:37
I hope they can sort it soon as it's not even accurate when you are forced to put it in lbs and it converts it to stone as that's what your preference is. Nor can you see your progress so frustrating
12-08-2024 13:32
12-08-2024 13:32
When I enter my weight it will not let me enter stones and pounds. From setting changed to kg that works. Set back to stones only option to input is pounds when entering new weight.
Does anybody else have this issue?
