Since latest update when I enter my weight it will not accept stones. From setting changed to kg that works. Set back to stones only option to input is pounds when entering new weight. Same on both android devices i use tried logging out and in, reset all devices too no change
Hi has this issue been sorted yet as I still cannot enter my weight in stone and lbs...When I enter it in pounds and it changes it to stone and lbs it is inaccurate 😤
Best AnswerNo not resolved and same problem if entering in pounds does not convert to stones correctly
Best AnswerIt's about time fitbit resolved this issue.
My Fitbit scales have issues logging my weight so I rely on this. Since November's update I have not been able to log weight in stone.
There are multiple threads which seem to get merged with no action. How hard can it be to add this back in.
Totally fed up with this, thank god it's pay day coming up, next month I can replace the scales and uninstall Fitbit.
Best AnswerHello, I see your answer is dated some time ago. Is there any update to this? We in the UK tend to use stones, not pounds. It's not helpful to suddenly make everyone use a metric they don't use. Thanks.
Best AnswerHi I am in UK still on fitbit not google. No update to fix yet fb do not seem to want to fix
Hi everyone!
I have great news to share with you. Based on your feedback, our team has developed a new version of the Fitbit app that will allow you to log your weight in stones and pounds.
Please note that this update is being rolled out in phases. If you don't see it yet, check back later and make sure to install it as soon as it becomes available.
I truly appreciate your patience and ongoing support. We value each of your comments and we are committed to continuously working to improve your experience with our products.
Best AnswerHow can you LOSE the ability to update weight in stones when it was there before? This American centric development puts me off Fitbit and if this isn't resolved in the next week I'll be off to Samsung Health. Shame.
@Jackieja Don't update your app. As soon as you do you will lose that ability to use Manage Data as the last update removed it.
I was happily using it and then I upgraded my phone and downloaded the Fitbit app and I lost it.
