07-29-2015 19:37
07-29-2015 19:37
12-31-2015 13:52
12-31-2015 13:52
@JEMJThank you for sharing what worked for you!
You're in luck! We have a help site here too! Hope that helps you out next time you need some further assistance! ![]()
@JulitoYou're right! With Android, there are lots of factors such as phone hardware, OS system such as Android 5.0, 5.1, 5.1.1, 6.0 etc. Glad to hear that the new S6 Active is playing well with our app. Happy New Year! ![]()
Best Answer01-06-2016 15:38
01-06-2016 15:38
Best Answer01-08-2016 19:32
01-08-2016 19:32
Thank you so much. It finally worked for me with your steps.
Best Answer01-08-2016 23:19
01-08-2016 23:19
Thank you so much, this issue has been driving me mental since i got my fitbit. Almost to the point as to splashing out for a new Phone!!...
Thanks for sharing!
Happy fitbit'ing
H.I.I.T every day >
Best Answer01-09-2016 04:14
01-09-2016 04:14
01-14-2016 13:09
01-14-2016 13:09
@Dennis13k If you're having issues with syncing, I recommend trying out the troubleshooting steps provided in this help article. Hope that helps.
Best Answer01-30-2016 20:50
01-30-2016 20:50
Best Answer02-01-2016 10:40
02-01-2016 10:40
Best Answer02-01-2016 15:31
02-01-2016 15:31
Best Answer02-01-2016 16:27
02-01-2016 16:27
Best Answer02-01-2016 20:07
02-01-2016 20:07
I followedk the directions and downloaded both apps. At the moment it is synced. I hope it stays connected. I've had this thing about a week and I really want it to work.
Best Answer05-08-2016 10:15
05-08-2016 10:15
Best Answer05-15-2016 12:56
05-15-2016 12:56
Excellent thank you, I have lost several hours of my life today trying to fix my sons fitbit, he's over the moon now thanks to your solution.![]()
@ngg wrote:
Hi
Since purchasing my Charge HR I haven't been able to sync it to my Samsung Galaxy S4 at all, like many people on here.
I seem to have solved the sync'ing issue between my phone and my Charge HR, it might work for other S4 owners?
I downloaded the app's 'BLE Checker' and 'Bluetooth LE Scanner' from Play Store to see if my phone was Bluetooth Low Energy enabled/capable.
I ran both apps. After running 'BLE Checker' it confirmed 'BLE Supported' so I closed the app.
I then used 'Bluetooth LE Scanner' to scan for the Charge HR - it found an 'unknown device', I tapped this and then selected 'connect', which it did.
Sync'ing then commenced without any problems.
I initially thought I'd have to run one or both apps to sync in future but the S4 and Charge HR are now sync'ing without either app running.
S4 is running 5.0.1.
Hope this helps others, if anyone else uses this procedure please post your results.
05-23-2016 06:16
05-23-2016 06:16
You are the real mvp. I almost gave up after a day of fussing with it and this was the last thing I was going to try before taking it back to the store.![]()
05-28-2016 22:05
05-28-2016 22:05
Thank you thank you thank you!! I'd had my fitbit for nearly a year when it started having sync problems. I'd have to turn off the phone and the fitbit and then restart both to get them to sync. Really annoying. When I emailed customer support they told me to un-pair it and re-pair. Big mistake, then it wouldn't connect at all. I've tried all their suggestions and even demanded they send me a new tracker but nothing worked, not even the new one. Finally I found this post and tried it and lo and behold it actually paired with my app!! Of course none of the past 3 week's information seemed to have saved but oh well. Thanks again!!
Best Answer05-29-2016 13:45
05-29-2016 13:45
Best Answer05-29-2016 13:50
05-29-2016 13:50
Best Answer07-07-2016 17:26
07-07-2016 17:26
OMG - YOU ARE MY HERO!! Works perfectly. Thank you so much for your detailed, well written and very successful instructions! I have had problems syncing my Samsung Galaxy 5.0.1 since 2 months after purchase, about a year ago. Using location services would sometimes help, rebooting phone sometimes, etc. But really, it was hit or miss. This is the first time I can remember in months that I have been able to look at the dashboard on my Fitbit app and see it sync! Thank you again!
07-08-2016 13:18
07-08-2016 13:18
Best Answer08-15-2016 00:51
08-15-2016 00:51
