07-16-2018
17:06
11:16
JuanJoFitbit
07-16-2018
17:06
11:16
JuanJoFitbit
Hi
I'm fedtup with my aria 2 scale. Everyday it disconnects from my wifi. I have no issues with my other wifi devices, the only pain is the aria 2.
My router is about 5-10feet away from the scale. Signal strength is not an issue.
I thought DHCP was an issue. So I assigned the scale a static ip. No luck the issue is still there.
You may ask, do I have the lastest update. The answer is yes.
My 2.4ghz wifi is set to 802.11bgn
I don't know what to do anymore
moderator edit: format
10-20-2019 15:49
10-20-2019 15:49
I have the same issue with my Fitbit Aria 2. I have tried anything that you say in this thread and nothing seems to work. What could I do?
12-21-2019 08:33
12-21-2019 08:33
I am also having the same issue. I have tried numerous times to reconnect the Aria 2 to my wifi and keep getting a weak signal indicator. I am getting so frustrated because I was loving this product until now.
02-15-2020 16:39
02-15-2020 16:39
Same issue EVERYONE has been having and the offered solutions by FitBit do not work.
I have removed batteries, reset, etc.
Just keep getting WEAK SIGNAL message.
