08-08-2015 18:00 - last edited on 09-10-2019 14:53 by MatthewFitbit
I have been trying to set up my scales. I go through almost the whole process until its trying to connect to WIFI and then a "WIFI ERR" shows up on the scales. I have checked my settings on my modem and it is on WPA2 PSK. I have also reset the modem more then once and tried the set up various times with no sucess. Does this have something to do with my modem? I have never had so many issues trying to set up one of my devices and I am considering just returning your item as I didnt realise I would have so many issues (obviously I dont want to return it). Can anyone shed any light on this issue?
11-06-2018 14:32
11-06-2018 14:32
Utterly useless advice. "we installed cheap, low-grade, low-bandwidth wifi equipment in the scale, now you have to dumb-down your 802.11G router to get this crappy old '802.11B' technology to work." Might as well have said "some unicorns are pink, and others are not, call your (worse than useless xfinity) cable provider..."
11-07-2018 04:30
11-07-2018 04:30
I hate this scale with a passion. I can’t understand why they can’t fix their technology. I’m waiting for this crappy scale to commit suicide. Then I can trash it and get a scale that actually works.
11-12-2018 07:37
11-12-2018 07:37
@SofaKingOverIt Welcome aboard to the Fitbit forums! I know how frustrating this is for you. Our team is aware of the issue and may not be able to provide a fix in the immediate future. We understand that this is not the resolution that you were hoping for but rest assured we are always working to improve our products.
@hopentyler Thank you for your feedback.
11-12-2018 17:51
11-12-2018 17:51
11-12-2018 18:58
11-12-2018 18:58
How do I get removed from this thread!!! It’s annoying already.
11-13-2018 09:21
11-13-2018 09:21
From the email if you scroll down you should be able to see unsubscribe.
11-14-2018 06:09
11-14-2018 06:09
Thank you all for your comments. Regarding your question, you can unsubscribe from the thread by going to top of this page and locate a "gear" icon located at the right of the subject and click on it. After this, select "Unsubscribe" from the drop down display.
I'll be around if any questions arise!
11-29-2018 20:41
11-29-2018 20:41
After a couple of months i decided to fix the issue I had with Aria today- WIFI ERR gone;fixed;solved! 🙂
Here is what I did
1.Connected to my router gateway - I use xfinity for internet and was able to connect to router with http://10.0.0.1/ in some cases this can be 192.168.0.1. Pls check online on how to connect to your router.
2.Updated WIFI 2.4 ghz mode to 802.11 b/g/n ( Earlier, when it was erroring out the mode was 802.11 g/n)
3.After the WIFI setup is completed. Please follow setup with Aria but taking out the battery and you will see setup active and follow setup.
These steps fixed the issue. Hope this helps others.
12-05-2018 05:44
12-05-2018 05:44
@harikumar It's great to see new faces in our Fitbit Community. Welcome aboard! I'm so glad to hear that you managed to resolve the issue and I appreciate your time in sharing the workaround that helped you to get this issue fixed. I'm sure this will help other users that experience the same issue.
Have you heard about our Discussions board? In this board, you'll be able to tell your stories, meet more people and start your own topics.
See you around!
12-11-2018 09:46
12-11-2018 09:46
THANKS! I was able to get it working just by doing step b):
Ensured that my wireless mode was set to: 802.11mixed (n/g/b)
12-11-2018 12:29
12-11-2018 12:29
12-11-2018 12:51
12-11-2018 12:51
12-11-2018 14:50
12-11-2018 14:50
12-11-2018 14:56
12-11-2018 14:56
12-11-2018 15:12 - last edited on 04-10-2021 07:19 by JuanJoFitbit
My bad, I guess my Aria would have worked with 5Ghz a few years ago but I
set it up on 2.4Ghz and it worked for years. My ISP switched to a different
router and the scale stopped working. They recently switched again to
handle 200/20 service so I thought I would try again.
My first setup was a piece of cake this time not so much. Maybe it will
work with your settings.
Thanks
That’s right, only 802.11b and not the 802.11 b,g,n protocol that is most likely on your router. If you want more insight into the status of 802.11b you can read more at
Sorry but you need to read what the moderator, Ferdinandfitbit wrote at the top of this thread the Aria only operates on 802.11b protocol if your router lacks that option you need to find an older router that supports 802.11b and b only.
heres the story...
https://blogs.it.ox.ac.uk/networks/2012/07/02/disabling-802-11b
Moderator edit: merged reply
12-11-2018 20:14
12-11-2018 20:14
12-12-2018 05:16
12-12-2018 05:16
@gariti That's great news! I'm so glad to hear that you managed to get your Aria scale connected to your network. Thank you for posting the steps you followed.
@ECM68 I was able to get in touch with our Support team and told me that you had a chat conversation. I would like to know what was the outcome.
See you guys later!
12-12-2018 13:48
12-12-2018 13:48
12-14-2018 08:02
12-14-2018 08:02
@ECM68 I apologize for the confusion on my end and I'm sorry about the experience you've had with your Aria scale. I really understand how frustrated you are and I appreciate your feedback and comments since this helps us to keep improving.
12-23-2018 08:12
12-23-2018 08:12
I just moved and I have to use the internet companys router to have internet. The Router is 802.11ac, does Aria not work with this router because I continue to get the “WiFi ERR” msg.
