08-08-2015
18:00
14:53
08-08-2015
18:00
14:53
I have been trying to set up my scales. I go through almost the whole process until its trying to connect to WIFI and then a "WIFI ERR" shows up on the scales. I have checked my settings on my modem and it is on WPA2 PSK. I have also reset the modem more then once and tried the set up various times with no sucess. Does this have something to do with my modem? I have never had so many issues trying to set up one of my devices and I am considering just returning your item as I didnt realise I would have so many issues (obviously I dont want to return it). Can anyone shed any light on this issue?
12-23-2018 08:20
12-23-2018 08:20
12-23-2018 08:23
12-23-2018 08:23
Okay, I will look into my router settings. Thank you!
12-23-2018
08:26
08:13
JuanJoFitbit
12-23-2018
08:26
08:13
JuanJoFitbit
If you have the Aria first version. It is only compatible with 802.11 b. My
router, from my internet provider. Has a b,g,n mode that (I thought)
should work but didn’t. For the time being, I am using my Aria as a
ordinary bath scale. When I have time I plan to dig through my assortment
of WiFi hardware to see if I still have a router that is compatible.
Hope you find this helpful. If you come up with another solution, e-mail me.
If I had a dollar for every time I’ve tried to fix the WiFi err I could
easily pay for an Airia 2 that is compatible with my router. I have tried
every “fix” suggested on the blog with no success. When I get a chance I
will try to find an old router that has a setting compatible with 802.11
b. For the remainder of the holidays I will use my Aria as a dumb scale.
Regards,
Moderator edit: merged reply
12-24-2018 08:13
12-24-2018 08:13
@CLO22 Thank you for joining us in this thread and our Fitbit Community! I would like to follow up on this issue and would like to know if you were able to change the router protocol to 802.11b as @gariti mentioned, which is the protocol that the Aria scale needs to be set up.
Looking forward to your response!
12-24-2018 11:08
12-24-2018 11:08
You will delete this comment, but I don’t appreciate seeing repeatedly that you understand how frustrating it is and that we are helping you solve the issue. It’s been a year, the issue is not solved, people are just as frustrated.
12-24-2018 11:29
12-24-2018 11:29
12-25-2018 04:12
12-25-2018 04:12
I changed Internet Provider (and wifisetup) some months ago, and since then the scale has not been working. I have now read through the info in this thread, and tried to apply whatever changes with lowered security (however, I will never reduce to WEP if that´s required), pw without "underscore", 802.11 b only (even though my router seems to only support setting b/g/n). Nothing works.
So, my conclusion is - it ends up in the wastebin forever. Expensive and crappy scale - will never buy anything more from fitbit for sure!
12-25-2018 04:24
12-25-2018 04:24
12-26-2018 03:33
12-26-2018 03:33
01-04-2019 08:00
01-04-2019 08:00
Tried syncing to my new wifi for about two hours.
My wifi name and password were already simple (no special characters or spaces).
I had to call Rogers and have them set as per previous commenters suggestion
(Updated WIFI 2.4 ghz mode to 802.11 b/g/n (Error was in mode 802.11 g/n))
Rogers did note that this change may slow my connection speeds on other devices, as the /b technology is older. Will see if having the fitbit synced to wifi is worth it. May be bin time.
01-07-2019 05:36
01-07-2019 05:36
@akasharaine Welcome to our Fitbit Community! I'm sorry to hear about the setup difficulties you've experienced with your Aria scale. I would like to follow up and would like to know if the issue persists or if your Aria scale is syncing with your network.
I'm afraid that the Aria scale only connects with routers running the protocol 802.11b.
I look forward to your response!
01-07-2019 22:59
01-07-2019 22:59
01-08-2019 07:23
01-08-2019 07:23
@ECM68 I understand how you feel about this and I appreciate your feedback. Since you mentioned that you will try other routers, please make sure that they run the protocol 802.11b, bandwidth 2.4GHz and the WiFi password is alphanumerical.
I really appreciate your efforts with this.
01-10-2019 09:55
01-10-2019 09:55
01-12-2019 09:58
01-12-2019 09:58
Yesterday, the during a technical with with fitbit, they said I need to connect to b/g/n as I have xfinity- is that correct? I was connected and then it stopped working and now it's saying "wifi err". I did not do anything from when it was connected to now receiving error messages.
Now are you saying I have to change my password? Why is it that every device and phone connects great, but a scale can't connect?
I've now spent 3+ hours working on this and I'm giving up.
01-12-2019
20:36
03:04
JuanJoFitbit
01-12-2019
20:36
03:04
JuanJoFitbit
The first gen Aria is only compatible with 802.11 b the earliest protocol
available. The industry began phasing out 802.11b in 2012 as newer faster
hardware became widely available. My understanding is that the b protocol
is very different from what is common today. I have 7 devices using the 2.4
GHz band with g or n protocols. My theory is that as the router transmits
and receives data on g and n devices, there is a lapse in the b protocol,
the scale can’t find the signal and loses the connection long enough to
trigger the WiFi Err.
I have an old router I used when I traveled for business and many hotels
only provided Ethernet connections to the internet. I plugged my ASUS WL330
Ge into the Ethernet and power and had my own WiFi. The router only does b
and g protocols so I am experimenting with setting the SSID as 4aria and
going through the setup on the Fitbit website I was able to briefly get my
scale to connect which is a step in the right direction. When I have time,
I will do more testing but at this point I think the second router, the
older the better.
There are very specific rules on what the scale can work with.
2.4GHz and 802.11 b protocol
SSID and password can only contain letters and numbers
I believe the security has to be WPA2 but I would check to be sure
I plan to test with no security to see if I can get the scale to connect
and if that works, try adding security protocols and passwords until I have
a stable connection.
Is all this worth the trouble? Probably not but it gives me something to
do. 😕
Thanks for the tips to get my scale reconnected. I would like to add my experience for the benefit of frustrated owners of the early version of the Aria scale. I finally decided my router/modem from my internet provider would never work with my Aria. Even in 802.11b,g,n mode.? I dug through all my old WiFi hardware to find a 802.11 b gateway with WPA security. What I have is an ASUS WL-330ge that I used on the road before all motels all went WiFi. They are still available on eBay for a reasonable price and in the advanced settings there is an 802.11b with WPA option. As far as I know this is the best solution short of buying a current model of the Aria. After setting up the ASOS router with a SSID of 4Aria and a nine digit password and connected the ASUS router to my modem/router with an Ethernet cable. I then went to the Fitbit.com/scale/setup site and followed the instructions to connect my Aria. In short after a month of struggling to understand the requirements of Aria and it’s incompatilty with current WiFi hardware, coming up with a a practical solution. If you don’t want to buy the ASUS router I have, start digging in that closet where you keep the stuff you thought you might need someday and look for a 802.11b router. It works if you set it up right but I have to say, the Aria scale is one of the most difficult pieces of technology I’ve seen. User friendly it ain’t. If you have questions feel free to contact me.
01-14-2019 16:18
01-14-2019 16:18
I'm having this same issue. What is a router protocol and if my router is running the wrong one how do I change it?
01-14-2019 20:09
01-14-2019 20:09
01-17-2019 03:15
01-17-2019 03:15
@carmenr88 Thank you for joining us in our Fitbit forums and it's great to see you here @obreezy89!
Regarding your question, yes, the Aria scale requires the protocol 802.11b and bandwidth 2.4GHz. Regarding the WiFi password, as long as it's less than 31 characters and doesn't have special characters, is good. Does the password comply with these details?
Also, the information that shared @ECM68 is perfect.
Please let me know if the issue persists!
01-17-2019 12:22
01-17-2019 12:22
