05-10-2017
17:53
14:53
05-10-2017
17:53
14:53
Even with new batteries, the Aria keeps turning on and off until the batteries die. It will not recognize me, I'm always a guest. But, it recognizes my wife right away.
05-11-2017 09:28
05-11-2017 09:28
@wpeggleston It's great to have you aboard in our Fitbit Community! Seems odd that your Aria scale turns on and off all of a sudden. Please take out the batteries again and clean the contacts of the Aria with a cotton swab and a little bit of alcohol. This will remove dust that the contacts may accumulate.
After cleaning the contacts, weigh yourself 5 consecutive times in order to re-calibrate your scale and check out if it recognizes your user.
Keep me posted on the outcome my friend! ![]()
Best Answer05-11-2017 10:36
05-11-2017 10:36
Best Answer05-15-2017 06:20
05-15-2017 06:20
@wpeggleston Thanks a lot for taking the time to troubleshooting this issue! Please don't hesitate to get back if more help is needed.
In the meantime, I'd like you to visit our Discussions board where you can share your experiences, meet people and create new topics.
See you later my friend! ![]()
Best Answer07-07-2017 06:12
07-07-2017 06:12
All of a sudden I am having the same problem. The scale is just over a year old. I'm going to try to clean the contacts.
HOWEVER, $149 for a scale is a huge amount of money.
There are other threads on here on here dating back to 2015 with this same problem. I haven't seen any solution yet. I'm going to be really upset if this problem isn't resolved and get "oh it's out of warranty". It's a known problem. It should have been addressed a long time ago.
07-07-2017 06:18
07-07-2017 06:18
D
@wpeggleston wrote:
Thank you for the input. I will give that a try tonight.
Sent from my iPhone
Did that work?
Best Answer07-10-2017 05:24
07-10-2017 05:24
@sogafyrfytr Thanks for joining us in this thread and our Fitbit Community! I understand how you feel in regards this issue. However, I would like to follow up and would like to know if the troubleshooting steps shared above, helped you to get this issue resolved.
Looking forward to your response my friend! ![]()
Best Answer07-28-2017 13:51
07-28-2017 13:51
No, cleaning the contacts and the battery compartment did not work.
07-31-2017 07:01
07-31-2017 07:01
@sogafyrfytr Thanks for getting back and trying the troubleshooting steps recommended above. Since the issue persists, I'll forward your case to our support team so they can investigate further and provide solution. You should receive an email from them soon.
Let me know if you have additional questions my friend! ![]()
10-11-2017 21:05
10-11-2017 21:05
I would add to this - my scale is perhaps 2 years old, and it from time to time goes into the constantly-on mode. This drains the long-life battery in 2 months at most.
The scale is clean, no dust, etc. Taking the batteries in and out does not help much more, it only adds the setup process to go through again. Obviously I am not treating seriously the advice to clean the contacts as this is pretty random advice and rather proves there is little knowledge on the root cause.
Support Team - would you please share what the root cause of the well-known for a long time issue is? I think the community of customers would appreciate the outcome of your investigations and hopefully with time see some solutions on the horizon.
Thanks!
10-11-2017 21:30
10-11-2017 21:30
I have the exact same issue. Very frustrating. Seems like the product was engineered to last 12-18 months. Mine is out of warranty so I guess there is no recourse.
10-12-2017 05:53 - last edited on 02-02-2020 13:56 by LiliyaFitbit
I have done everything Support has asked me to do. But still the problem remains. If I buy batteries for it regularly I use a 4 pack of AA alkaline batteries about every 10 days.
Sent from my iPhone 7+
10-15-2017 06:36
10-15-2017 06:36
I have the same issue and am not pleased to hear they will not fix it. I guess I will look at other brands.
11-11-2017 13:40
11-11-2017 13:40
Same issue now for 3 months
Scale start running on its own
11-11-2017 18:35
11-11-2017 18:35
Same thing here. About 1.5 years old and now just burns through batteries. I walk by it and see it on when nobody has used it. Cleaned contacts everything they said, the only thing left to do is put a "on-off" switch on the **ahem**. With no more help from the manufacturer, I will never buy another one of thier products again. RIP Aria.
11-14-2017 23:05
11-14-2017 23:05
same thing happened to me mine is 18 months old out of warranty with no solutions, Scale is too pricey to only last this long. Very unhappy
12-28-2017 08:18
12-28-2017 08:18
Below is an email I just sent support in response to my ticket.
I have tried all you have asked. But nothing is correcting this problem.
I have seen several new posts from other users since my original reply to this post, saying they have the same problem but still no solution.
Every user is replying back they are following suggested troubleshooting steps.
It is apparent this model is greatly flawed.
03-05-2018 17:09
03-05-2018 17:09
My aria is doing the same thing as the others on this thread. Are there any solutions to this problem? I love the scale but it keeps turning itself on.
Regards,
Robert
03-06-2018 06:57
03-06-2018 06:57
10-03-2018 02:47
10-03-2018 02:47
mine is also doing this hence coming on to look for a solutuion
everytime I go to get on batteries are dead, take them out re do all the cufuffle and use, happy days. Ive noticed then that when i put the scale away with nothign touching it it keeps coming on and "sensing"
next time i use the scal suprise suprise batteries dead
costing a fortune in batteries
