01-17-2018
07:30
08:45
01-17-2018
07:30
08:45
Trying to setup scales changed network and have got to the stage saying Active setup but when l go to settings and try to connect to the Aria network it's says network not avabile can anyone help as l am trying to set these scales up know for 6 months
02-16-2019 15:19
02-16-2019 15:19
I have a tenda router and I'm having the same trouble. I set it to the 2.4 setting only. I get through the entire set up until the end and then it won't connect. What is the issue?
Best Answer02-19-2019 03:30
02-19-2019 03:30
@mvasaly I'm sorry to hear that your Aria is not connecting to your network either. Thank you by the way for making sure that your router runs the bandwidth 2.4GHz. I would just like to know a couple of extra details: Is your router running the protocol 802.11b? Is your Aria displaying any error message? Does your WiFi password contain special characters?
Looking forward to your response! ![]()
Best Answer02-19-2019 04:35
02-19-2019 04:35
Best Answer02-20-2019 05:22
02-20-2019 05:22
@mvasaly Thank you for getting back! Please contact your Internet service provider so they can guide you how to find and change the protocol that your router is running.
I appreciate your patience and time with this.
