01-05-2014
11:20
14:53
01-05-2014
11:20
14:53
I got all the way to step four and it shows it is connected to my wifi but during step four on the mobile set up it says connecting as last step and never does. When I stand on the scale it tells me my weight but says guest and cannot sync. Help please !
Moderator Edit: Title edited for clarity
10-29-2018 09:37
10-29-2018 09:37
@eileen1011 Thank you for providing more details about your WiFi. Please make sure that your new router complies with the settings that are listed in this help article. If you need help to change the settings, please get in touch with your Internet service provider. Finally, make sure that your WiFi password contains letters and numbers only.
If the issue persists, let me know and I'll be happy to follow up!
01-05-2019 17:49
01-05-2019 17:49
Mine is going to have the same symptoms soon. Been trying to change my network for about 10 months now. Why do you do this to us Fitbit?? Seriously?!
01-05-2019 20:59
01-05-2019 20:59
01-10-2019 06:35
01-10-2019 06:35
@AngryAria Welcome to our Fitbit Community! I'm sorry to hear that you are also having a hard time while trying to set up your Aria scale. I'd also like to know what is the make and model of your router. This will help me to proceed and assist you accordingly.
@eileen1011 I totally understand how you feel about this and I appreciate your feedback. I would like to know if the issue persists even after changing the router settings to the ones that are listed in the help article shared in my previous post.
I appreciate your patience and understanding with this guys.
01-10-2019 15:06
01-10-2019 15:06
01-16-2019 07:35
01-16-2019 07:35
@eileen1011 Thank you for providing the details of your router! Since the issue persists, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You should receive an email from them soon.
Let me know if you have any doubts!
01-16-2019 14:34
01-16-2019 14:34
Hi! the XB3 is a comcast gateway. You need to make a few changes to you network setting in the model for the Aria 1 scale. Th Aria 2 scale does not have this issue.
All comcast routers use the standard protocol fo network connectivity. 802.11ac. ( This is the latest and most secure protocol for wifi communication.
I believe the Aria scale supports only an out dated but still secure network protocol... I think it's 802.11 a, b, g, or n. I forget whcih one it is. but you need to get into your router's configuration setting by typing '10.0.0.1' into your browser address bar when connected to the router. you will be promted for a username and password, and as long as it was never set, the username is 'admin' and the password is 'password' . From there you need to find where you can change the protocol setting from 802.11ac to also used 802.11b ... or 802.11n I think. I had to do this myself a while back, but memory is fading on the exact protocol it work on. I ended up getting and Aria 2 scale and gave the Aria to my sister.
01-16-2019 14:59
01-16-2019 14:59
01-17-2019 06:35
01-17-2019 06:35
02-23-2019 11:04
02-23-2019 11:04
Hi - I finally received the information that I needed from a fitbit team
It took months to get this resolved but my scale is now connected to my network.
I needed to make a small change to my route in my xfinity account
Thanks for all the help.
Eileen
02-25-2019 03:19
02-25-2019 03:19
@eileen1011 I'm so glad to hear that your Aria scale is now connecting with your network properly. Thank you for posting the update here.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often!
03-17-2019 12:40
03-17-2019 12:40
I have struggled with this for weeks when I changed my router. There is a tiny hole near the battery compartment on the back of the aria. It is a reset button. Worked first time.
03-18-2019 07:12
03-18-2019 07:12
@GuernseySue It's great to see you here. I'm sorry about the difficulties you've experienced with your Aria scale.
Since you mentioned that you've changed your router, please let me know what is the make and model of your new router. Also, please let me know if you are getting any error message during the setup process.
As a side note, we don't recommend pressing the hole that is on the back of the scale since pressing it often, might get the scale damaged.
See you later!
03-18-2019 07:20
03-18-2019 07:20
It is sad that people are so frustrated by the problems with their scale that they are using the hole at the back of the scale even though the company doesn't recommend it. Even sadder that it worked for someone and so I tried it out of desperation and of course no luck for me!
03-18-2019
07:52
04:20
JuanJoFitbit
03-18-2019
07:52
04:20
JuanJoFitbit
This is what I was told I have back in a thread from January..
In February we got the scale to connect -- this worked for two days.
I have the XB3 comcast gateway router
I was directed on what changes to make in February -
I made the changes and the scale worked for 2 days.
Now it will not connect again.
Eileen
Moderator edit: merged reply
03-27-2019 04:29
03-27-2019 04:29
@eileen1011 I'm sorry for the late response. I'm also sorry about the connectivity issues that you are experiencing with your Aria and Comcast router. Our team is aware of this and expect to have a solution soon. They're actively looking into this and once a solution is available, we'll make sure to post it in the Community.
Your feedback and patience is greatly appreciated.
03-27-2019 19:47
03-27-2019 19:47
So I've tried the option of setting up 802.11b however my router does not allow to the option to switch to 802.11b only 802.11n or 802.11 g/n.
Is there anything else I can do or is my scale rendered obsolete?
03-27-2019 20:37
03-27-2019 20:37
03-30-2019 04:44
03-30-2019 04:44
@Dominich77 Welcome aboard to our Fitbit forums! I'm sorry to hear that your Aria is not connecting to your WiFi either. Please contact your Internet service and see if they can switch the protocol to 802.11b or mixed mode (b.g,n).
In the meantime, please let me know what is them make and model of your router.
Looking forward to your response!
02-04-2020
08:41
11:05
JuanJoFitbit
02-04-2020
08:41
11:05
JuanJoFitbit
Perhaps you could share what they said to change so the rest of us don't have to wait months.
Thanks.
I am having the same issue. Cannot connect. I use Frontier (Verizon) modem and the Linksys MX10 Wifi 6 mesh system. I have a mesh unit about 15 feet from the scale's location. I got it to connect once. I have tried, and retried, and manually entered and retried. It continues to look for the wifi, and when I try to reconnect it doesn't see the network. The Linksys is backwards compatible. Even though it means weight loss, I am tired of giving my blood, sweat, and tears over this thing.
