05-17-2018 12:32 - last edited on 09-04-2019 08:45 by MatthewFitbit
My Aria 2 scales have just stopped connecting to wifi - have read a couple of things on here about wifi settings needing adjustment which I dont understand. The wifi has not changed? Can anyone help its driving me crazy
10-20-2019 09:39
10-20-2019 09:39
All
I too had experienced the chg after the many iPhone updates
i tried the following and my scale is syncing again
1. Shutdown your fitbit
2. moved my scale to living room next to modem and once I weighed it synced and recorded my weigh
hope this helps!
08-10-2020 15:11
08-10-2020 15:11
I know its an older thread, but I had exactly the same problem. After around 18 months my Aria 2 stopped syncing and displayed the message "Can't connect". Intermittently it would sync but the problem just got worse and worse. I tried everything I could think of, reconnecting to WiFi etc and sometimes it would work, other times not.
I suspect there is a slight bug in the software as the batteries reported as medium charge, but fitting brand new batteries fixed it. I hope this helps someone.
10-28-2021 08:51
10-28-2021 08:51
I started having the same issue - noticed after I weighed myself that the upload indicator was still spinning... hours later, still spinning. I've had the Aria for several years with no issues. Now I have tried setup 6 times, even moving the scale within 10 feet of my router, and no luck. It's on a flat surface and no special characters in the wifi password. If I cannot get it to work, since it is out of warranty, I will likely buy a different brand to replace it. Can anyone help?
11-15-2021 03:35
11-15-2021 03:35
Apparently there is no fix. This thread was started in 2018. I’ve had 2 arias, and now I’ve had the aria 2 since January 2019 and it’s always the same issue! No longer connects to WiFi. It seems it’s just like the cell phone, every 2 years you gotta get a new one. Since G00gle bought Fitbit it seems things are very different. Bots reply now and no answers.
