Update 11/8/2019: Hi everyone - this issue has now been resolved. Thanks again for your reports and patience.
Hello Aria Air customers - we are aware of an issue that is currently preventing your Aria Air from syncing properly. If you set up Aria Air after 10/28, you will not be able to sync until this issue is resolved.
We apologize for the inconvenience, and are working to resolve this as quickly as possible. We will update this thread as soon as we have more details on this fix, and appreciate your patience in the meantime.
As noted earlier, this issue was resolved and your Aria Air should be syncing normally. If anyone is still having trouble with syncing, please check this article for assistance. Thanks for your patience while we worked to resolve this.
I just received an aria air today and I went through the whole setup procedure. when I step on the scale I can't get in to sync with my phone. The scale did not come with much instruction, and I have not been able to find much more online. when I go to Bluetooth settings on my phone the scale is not on the list of devices connected, or available to connect. I noticed that there is a Bluetooth light on the scale that only comes on for a split second every once in a while. there is nothing that I have found that tells me what these lights mean. Is my scale defective?
Same here! Got email this morning from Fitbit - Brand new Aria Air weight scale for only £49.90. Went happily to purchase one straight after work. Followed the setup, stepped on the scale, it shows my my weight but in the app it shows.. nothing?! Just "add weight manually". Great! Seriously Fitbit, this shouldn't be any rocket science. Make your product work before launching it or promoting it. This is the biggest **ahem** I have ever purchased and seriously thinking of smashing it against the wall. Never going to buy anything from this rip-off company.
Following as also having this issue. Tempted to return.
Same
Appears in APP but will not sync Weight
Latest APP update was last 18 Oct
Not very impressed
hopefully someone has some answers or I am sending mine back.
Wait for FitBit to fix it I suppose
They really do need a few lessons in modern business practice.....
Good job they don’t make cars....
Probably sell one that won’t go round corners 😜😜😜
I'm having the exact same problem. I was able to set it up no problem, it's listed as a device on my fitbit app, I've tried deleting it and reinstalling it, I've tried resetting it. Each time, it sets up and is added as a device, but won't actually sync my weight when the app is open.
The instructions say to have your fitbit app open to "Today", then step on the scale, and the weight will automatically sync - doesn't happen. I see the Bluetooth symbol flash in a nanosecond on the scale, and then nothing. I've tried setting my phone on the ground next to it even, and it still won't work.
I bought the aria air specifically because my original Aria scale refused to connect to my wifi and after over a year of trying to fix it, I just gave up and figured I'd settle for Bluetooth. Now this won't even work. So frustrating
10-31-2019
10:34
13:30
JuanFitbit
10-31-2019
10:34
13:30
JuanFitbit
Exactly the same as me
I was pleased when FitBit announced Aria Air as couldnt justify paying over £100 for the original
Early buyer so perhaps should have waited
Presume they will Fix this but no garuantee
Still no SPO2 a year after FitBit Charge 3
Very disappointed with FitBIt
WW
Chris
Sent from my iPhone
Moderator edit: removed personal information
Hi everybody! Thank you for your posts and information. For those, who haven't setup the Aria Air, or cannot sync it. Please verify that the mobile device you are using, has the Bluetooth on. Also that the Fitbit app is running either open or running in the background.
Please check that your device is not on Don't Disturb Mode (Silence) and that the Battery Saving Mode is off .
It's also needed that the Fitbit app is up to date.
We also recommend to use a compatible device when syncing the scale. Be aware, that if there are other scale users nearby, they should have the Bluetooth of their devices off.
You'll find these and more recommendations, as well as some tips in these articles. : Why won't my Fitbit device sync?
Why can't I set up my Fitbit device?
Please let me know if you have further questions .
10-31-2019
14:10
16:37
JuanFitbit
10-31-2019
14:10
16:37
JuanFitbit
Ok
Scale appears in the App so obviosly connected
Doesnt show as connected device in my BlueTooth settings so probably not paired
Standing on scale doesnt sync to phone App
Loads of users reporting same issue
Got to be a software issue ( Im a Tech suport Engineer by the way )
Needs a quick fix as you have a large amount of very upset customers already
WW
Chris
Sent from my iPhone
Juan,
I have the most up to date version of the Fitbit App, neither my Do Not Disturb or Batt Saving Mode are on, and every time I step on the scale the Fitbit App is open and available.
The links you provide on "Why won't my fitbit device sync" are not helpful for the Aria Air because they focus more on wifi connectivity, whereas this is a Bluetooth connection issue.
I think it's safe to say that the problem is with the scale and software, and not with the users. How else would we all be having the same issue?
Same here, i can add it to my list of devices but it will not sync with my phone. And yes the bluetooth is one, no it is not in airplane mode, yes i have tried restarting the phone. Yes i have tried taking the batteries out of the weight for 1+ min. Yes i have tried reinstalling the FitBit App.
Hi @KRSogaard @SunsetRunner @SunsetRunner , thank you for your replies and further information. This has been very helpful.
If your Aria Air has different users linked to it, please remove the other accounts from the scale.
If the situation persists, please restart your scale. Please hold the inductive button for 5 seconds (you'll find a picture of it bellow) you should see on the display this message : oTA. Release the button, and press it again until you see on the display clr.
After restarting the scale, restart your mobile device (off /on)
Then, please setup the scale again to your account!
Please let me know how it goes.
@JuanFitbit I have done this at least 3 times, and it still has not made a difference. Each time I am able to add the device with no problem, but it will not sync when I weigh myself.
