"Something went wrong" during Aria Air setup
ANSWERED
There has been a consistent difficulty with setting up the Aria Air scale since Fitbit moved to Google. When attempting to pair the device, an error occurs. Scale issue.jpg
419 REPLIES 419
the problem in my opnion is a secutirity issue is nothing to do with hardware.
so the only people that can fix this are the fitbit themselfs
I agree that it’s an issue that Fitbit themselves need to issue an update / fix for asap. I’m so exhausted by customer services replying to my emails basically implying it’s my fault for not setting it up correctly and repeating their set up instructions to me. They just told me there was a Fitbit aria associated with my account and I needed to step on it to actually take my weight so it could sync…. But there is No scale associated with my account at all because setup kept failing 😂
 use the twitter Sara it helps
Feeling silly endlessly cycling through Bluetooth off/on, restart iPhone, press and hold reset to otA, press and hold to Clr, press and hold to 000. Worked okay until setup on new phone and transition from Fitbit to Google. That’s a lifetime worth of entering three digits + save wasted. A solution will be appreciated or ability to roll back from Google to Fitbit.
Still nothing for me.. This time the firmware did update but still only a guest and says that it synced but no results. I wouldn't say this is fixed just yet and the way that was provided doesn't seem to help at all
How do I sign up to be notified for a resolution? It seems the moderator has their "Best Answer" to this unresolved issue and closes the thread. How does Fitbit handle common unresolved support issues?
Obviously they ignore them.  I’m done.  I returned my scale and looking for alternatives with adequate support
If you didn’t say this I wouldn’t have known there’s a separate app for the scale. Thanks!
Hi,
Do you have an ETA of when this will be fixed?
Ta.
I found out one work around. If you live with someone who hasn’t switched to a Google account, have them set it up on their phone and invite you.
Sorry not super helpful
no but indicates where the problem is --
Moderator Edit: Personal info removed
I’ve set myself up with a brand new account associated with my non-google email account and have refused to sync it with a google account…. My scale has paired now with no problems. I have no history anymore for my Fitbit health trends etc but not a huge issue as I only recently started using it again. Looks like non-google accounts will only be supported until early 2025 - although I’m hopeful they’ll have a fix for the aria setup before then. So it’s definitely isolated to google accounts !
how did set up a different email ?--
Signed up as a completely new account. Not really a good workaround for people who have had their accounts for years but would help to do what OKKfran suggested above to set up the scale and ‘invite’ your usual account to use it:
https://www.fitbit.com/signup
It works
I advise everyone to use the sign up with a different email address
that is not google.
and magically will work .
Another thing is this machine isnt calculate your body fat percentage
Sorry folks, my work around didn’t work out. Ugh
Nothing but trouble since I converted to Google.  Clearly they did not test very much.
Got my return label and sending it back today. Hope it works out eventually for everyone
same problem from Korea, during clinical trial...  😧
I'm getting the distinct impression this is a low priority for Fitbit and I'll still be visiting this thread months from now looking for a real solution.
