06-13-2018 11:48 - last edited on 09-10-2019 14:53 by MatthewFitbit
Hi everyone! It has come to our attention that some users are experiencing issues with syncing/setting up Aria scales with Comcast/Xfinity routers and we are currently reviewing.
There is a workaround that has helped most users. For this, follow the instructions below:
Thank you all for your patience. Any update available, I'll make sure to share it in this thread.
04-11-2018 09:26
04-11-2018 09:26
As previously reported for Comcast/Xfinity Arris TG3482G modem/router not compatible. The day it was installed my Aria failed to sync regardless of any updates or sync attempts. Comcast is phasing out support of "b" formatted wifi on new equipment.
04-11-2018 16:20
04-11-2018 16:20
I tried those instructions exactly (several times) and still can not get reconnected. I also have Comcast and my make is Arris and model TG1682G. My dad has the same model as me and the workaround instructions worked for him last night but he was kicked off again today and cant get reconnected. Please help! I haven't been able to use my scale for months now.
04-11-2018 16:58
04-11-2018 16:58
Mobile apps developers, god bless them trying to keep up! But in this case, it’s become apparent that one source needs to be fixed. If we all have different internet providers, different routers, different operating systems, and none of the scales are working, fix the source! Think about it, all of the other Fitbit devices are working. Forget about the quick router fix, as yes, as soon as you reconnect the next day, the default settings kick back in.
04-11-2018 18:38 - last edited on 04-06-2021 06:09 by JuanJoFitbit
When will there be a firmware upgrade to deal with Aria's failure to connect to modern routers and remain secure? Otherwise, its just a piece of junk in my home right now.
I just found another issue is that the aria will only connect to routers using alpha numeric characters in their passwords. As you know, Uverse and other secured networks don't rely only upon alpha numeric characters. I don't plan on changing my secure password on 20 Hue Lights, my Nest, two phones, three Ipads, a Roku TV, two FireTV's, and 6 Echo devices because of the failure of Fitbit to keep current on security requirements. Very disappointed and actually quite angry.
Moderator edit: merged reply
04-11-2018 22:05
04-11-2018 22:05
04-12-2018 15:10
04-12-2018 15:10
04-12-2018 16:32
04-12-2018 16:32
I have been loyal to Fitbit since 2013. But I am so over this. I am also thinking about jumping over to Garmin. Ugh...
04-14-2018 08:35
04-14-2018 08:35
+1 for same issue, using xfinity (but seems that doesn't matter).
Have reconnected Aria multiple times, and it works for couple mins, then loses wifi again. On firmware v39
04-14-2018 12:57
04-14-2018 12:57
My Aria last synced on 3/28/18
I had been weighing myself every morning, and did not notice the wifi error until about a week later.
The scale is less that 3' away from the router. It appears other users have had similar issues around the same time, but all I can find on the forums are their similar complaints, no solution. An x appears over the wifi logo as an error message -it appears briefly after the sync icon tried for about 10 animations. There are no words or other warnings, That is why it took me a while to realize it wasn't syncing. I actually noticed the lack of data in my FitBit app before realizing the scale wasn't syncing.
04-14-2018 13:39 - edited 04-14-2018 13:44
Do you have a dual band router that runs on 2.4g and 5g? If so, your 2.4g mode is likely set to 802.11 g/n (standard) and the Aria requires it run on mode 802.11 b (which will basically kill off your 5g band from what I've been told). I just spent the last several hours undoing all the damage I did by changing my mode to b from g/n...
A scale isn't worth this mess. Looks like I'm done with Aria....
04-14-2018 13:49
04-14-2018 13:49
04-14-2018 15:06 - last edited on 04-06-2021 06:10 by JuanJoFitbit
Yes, I have a dual band router, but following all the recommendations did not help. New routers no longer support the “b” WiFi protocol required by the Aria series. Not to be serious but perhaps you rename the Aria **ahem**. No letters or special characters of course.
P-O-S renamed ahem by the auto correct
05-04-2018 09:52
05-04-2018 09:52
Thanks so much for this workaround. It worked pefectly the first time I did it. I believe when Xfinity (my ISP) does updates and reboots of there system I will need to do this from time to time but it's better than paying for a scale that does'nt work.
05-04-2018 10:01
05-04-2018 10:01
I have given up trying to fix this. It messes up almost every day and I personally am not going to go through the trouble. Now, when I weigh myself, I have my phone and enter the new weight. A Hassle.
As others have written, I wish Aria would acknowledge that this scale will not work. It should be front and center before anyone else buys this scale from now on. Comcast will not support the "b" technology so " Buyer Beware"!!!!
I have had the scale for several years so I understand the technology issue. What is disappointing is that the new Aria appears to have the same problem from what I have read. I'm not going to spend $150 on a scale that doesn't incorporate the newest technology.
05-06-2018 20:31
05-06-2018 20:31
Wow a big group of people with Aria issues around the same time. This look very suspicious. I suspect Fitbit pushed some software update to mess our older Aria scales to nudge us into buying newer ones or maybe their new version Aria 2.
"Last time my Aria recorded weight was on Feb 24, 2018.
Maybe with others we can find a pattern of when their scales stopped working."
05-08-2018 12:52
05-08-2018 12:52
I am so disgusted with Fitbit it's always the same. Customer service rep is script reading telling me to call Comcast. I bought this scale in July 2017 and as of March it will not sync. I am tired of troubleshooting and trying to get it to work. These products have been very ify lately my Alta gold series also. There has got to be a better product on the market. Nothing has changed I refuse to continue to indulge in anymore Fitbit products and I will be telling my friends also.
06-10-2018 12:57
06-10-2018 12:57
I have the latest ang greatest from Comcast ( XFi advanced gateway ) and b channel for 2.4 is not even an option g/n only
06-10-2018 17:23
06-10-2018 17:23
Reported this to Fitbit in April with no real response. They are not interested in staying ahead of technology.
06-10-2018 17:29
06-10-2018 17:29
06-12-2018 06:16
06-12-2018 06:16
This is what I have been doing as well.
