Blaze Screen flashing
ANSWERED
So I woke up and noticed my blaze screen is constantly flashing as if its showing the old school TV static screen. Any idea on how to fix this issue? This is the first time I've experienced this.
250 REPLIES 250
I had to let my battery died completely, and then after it recharged my blaze was fine.
Replace the battery because it's long time then reboot
Reset & tried sync... Bluetooth option was missing from menu. Reset & it came back but wouldn't sync or be detected.reset again & it's now flashing again & only responding to buttons. Several resets now an not responding to anything but buttons & still flashing
check your mobile blue-tooth,then shut down your mobile and start your
phone then you check your device and your fit bit device once again rest
may be it will work
I just now had the same problem - Blaze blinking fast.  I rebooted it and it works just fine.  Thanks much.
Been several days now and watch is responding and behaving normally except that the screen is still flashing and not displaying correctly. Tried removing from account & re-add to account. Several resets & restarts but the screen remains the same
Glad to help. Remember how you did it, I have had to do it again.
Twas a huge blessing... I just bought my wife a versa and wasn't trying to get another just yet! Thanks a million!
I lost my blaze but just found it and have been trying to charge but it is just blinking its logo.  Will this charge up?
Yes it will take some time.
Re Blaze:
I have tried to remedy the flashing diamond by pressing back and lower buttons but nothing has changed. Could you please advise.
Let the battery run completely down where it won't do anything but display the dead battery symbol, then recharge and it should be fine.
Trying some more time
Thanks a lot, I'll try this.
Kind Regards
I encountered  this issue with my BLAZE Fitbit.  It was malfunctioning with the flashing screen.  The suggested reset worked.  This has occurred a few times..  I am unsure if this is a persistent problem,  hope that it isn't.
Hi,
I tried to reset on numerous occasions but my back button doesn't seem to work.
I've given up on my fitbit now.
Thanks anyway.
Kind Regards
Sent from Samsung Mobile on O2
Hello;
if you go to settings and turn your device off you should see a reset happen.
Already reset the watch device several times every months since reporting this and before
Good day, I am having the famous flashing home screen on my fitbit blaze,
I have tried the 10 to 12 second reset and it had no effect.
Is there anything else i can do to repair?
Thanks.
Hi put you watch in a tub of rice and just leave it fir a couple of days. Then hopefully when you charge it back up it will work. Stay safe
Sent from my iPhone
