02-09-2018
06:47
07:53
FerdinandFitbit
02-09-2018
06:47
07:53
FerdinandFitbit
So I woke up and noticed my blaze screen is constantly flashing as if its showing the old school TV static screen. Any idea on how to fix this issue? This is the first time I've experienced this.
08-22-2019 07:16
08-22-2019 07:16
Followed your instructions and my blaze is working thank you
08-30-2019 14:49
08-30-2019 14:49
Hello @RDQ and @Evabo, welcome to the Community Forums! Sorry for the delay in responding your posts.
I'm happy to know that your difficulties were resolved after trying some troubleshooting steps, your effort and patience are appreciated. Please do not hesitate to contact me back if both of you need anything else or have any additional questions for me to answer, I'll be here.
I want to suggest to visit our discussion forums and participate. There are several users who are interested in fitness, healthy eating, better sleep, among others and I'm sure that they will be happy to meet both of you there.
See you around. 🤓
Best Answer09-09-2019 03:06
09-09-2019 03:06
Hi Ferdin,
That was great advice, I had the same problem and your advice sorted it straight away.
TopMan!
09-09-2019 06:07
09-09-2019 06:07
09-11-2019 03:37
09-11-2019 03:37
I tried to reboot and even that did not work. Screen just got dimmer.
Best Answer09-11-2019 07:32
09-11-2019 07:32
09-25-2019 20:44
09-25-2019 20:44
I had the same issue with mine. I reset it and it worked! Thanks for the suggestion.
09-26-2019 05:31
09-26-2019 05:31
11-03-2019 04:52
11-03-2019 04:52
Hi,
I have tried the reboot step and it didn't work for me.
The screen is still blinking with blue fitbit icon.
Please advise, thank you
Best Answer11-04-2019 06:41
11-04-2019 06:41
Best Answer11-05-2019 09:53
11-05-2019 09:53
Yay!! Thank you! It worked for me!
Best Answer11-11-2019 08:28
11-11-2019 08:28
My blaze doesn’t have a left and bottom button to hold. There is one left side button. Is that what I press and hold? Thank you
Best Answer11-11-2019 09:08
11-11-2019 09:08
Best Answer11-11-2019 10:14
11-11-2019 10:14
Best Answer11-11-2019 23:15 - last edited on 11-13-2019 11:27 by LiliyaFitbit
It worked!!!! Thank you! Thought I was going to have to get rid of it.
Took about 10 seconds
All In Tackle
Best Answer11-12-2019 04:29
11-12-2019 04:29
Best Answer11-18-2019 00:17
11-18-2019 00:17
My blaze doesn't reset after I hold the buttons in to try to fix the flashing screen
Best Answer11-18-2019 03:42
11-18-2019 03:42
Best Answer11-18-2019 06:54
11-18-2019 06:54
Best Answer12-10-2019 12:21 - edited 12-10-2019 13:06
My almost 2 year old Fitbit Blaze started with the flashing screen 2 days ago, and it WILL NOT reset no matter how long I hold down the left and lower right buttons. The buttons work individually so it's not them. Will it "reboot" if I let the battery completely die, and then charge it?
