Blaze Screen flashing
ANSWERED
So I woke up and noticed my blaze screen is constantly flashing as if its showing the old school TV static screen. Any idea on how to fix this issue? This is the first time I've experienced this.
250 REPLIES 250
@Phyllis1051, thanks for getting back and I'm happy to hear that it worked for you! 😄
@Lynn81 please have him contact the Support Team (click here) for more help. If you need more assistance, let me know!
Ferdin | Community Moderator, Fitbit
I have been having this issue for a couple of days with my Blaze. Battery seems to run down constantly. Let it run down yesterday, fully recharged in the evening. Wore to the gym this morning and halfway through the workout it just started flashing. Nothing would reset it, not even the manual reset with the left and bottom right button. Eventually it stopped flashing and displayed a clock face error. I managed to resync with a new clock face and then it worked late this morning. Then this afternoon I got another battery alert for low battery, despite it only being fully charged less than 20 hours ago, and by the time I had cycled home it started flashing again. Again, the manual reset won't work and it won't sync with my phone. Does anyone have any suggestions?
Wow!  I was experiencing the same issue- tried pressing the buttons for 10 secs and it worked!  Thanks, this made my day as I was wearing the Fitbit with the flashing screen for a few days!
Reboot Reset fixed the flashing screen
I haven't heard anything from support. This is my 3rd Fitbit. I'm done. If you (support) can't respond then I can see it's time to move on to another brand. It's a shame because I liked it and it was helpful with my everyday life, but they are too expensive to be buying new ones every 6 months. And I don't use them in extreme environments.
Thank you it did work.
Thank you!!!! Mine started flashing last night and I reset this morning! So far, so good!!!!
I have a FitBit Blaze. It flashes continually.
Update
The advice of pressing left and lower right button for 10-12 secs. did not work. Screen still flashing on my Blaze.
Hi Jogger, Have you tried going back to reset as if its  a new device and entering new numbers then holding buttons.Thats what i did to get mune to work again and stopped screen from flashing.
Hope this helps
regards
Max
It worked for me - did you hold it long enough?
Here is what I did:
The fitbit Blaze has a built-in way to reset that will stop the flashing. I
held down the left button and lower right button simultaneously for about
10 secs. The display shifts to TODAY then resets!
Moderator edit: Removed personal information.
Thanks for stopping by guys! How are you doing?
@Geogrose@StephNY@lwleake and @maz53 thanks a lot for all your efforts fixing this situation, it's great to learn that your Blaze is working fine now.
@Dirtyrice25I just checked with our Customer Support team and confirmed that you have a case open with them, they tried to reach you in November. If you don't find the email you can check in your Spam emails. I advise you to reply them and continue the assistance. Cat Wink
@FKM2020, I'm sorry to hear that this issue persist despite your efforts. I opened a case for you with our Customer Service Team, they will be contacting you via email very soon.
If you have any further questions, please let me know!
It worked.  Thanks
How do you reboot?  My screen is flashing too. Thanks!  Ellen
hi go into settings and scroll down to shutdown. press yes to turn device off then press any button to put it back on. sync as soon as it comes back on.this solved flashing screen
Update ‎01-28-2019 00:19
hi, my screen was flashing again so i went into settings and scrolled down to shutdown. pressed yes to  confirm. This turned device off, then i pressed  any button to put it back on and then  sync as soon as it came back on.this solved flashing screen.
Worked great!
Wow!!! Thank you so much!!! That did it!!
Ellen
Sent from Mail for Windows 10
Great to hear it worked for you too.
My Fitbit Blaze display started flickering yesterday and I did the reboot which fixed the problem. Happen again today and reboot or shutdown does not fix the issue anymore. I am going to let it drain all the battery and see if that helps or not. Bummer.
Oh I’m sorry. I guess I got lucky , shutting it down worked for me so far. Good luck!
Sent from my iPhone
Thanks for reaching out and sharing your experience @wellsdl@Ebrett@maz53 and @ChallengedSenio. It's great to know that your Fitbit devices are working good again. Cat Happy
How you doing @tron07? Thanks for joining this family, hope you like what find here! I'm sorry to hear that the issue persist even if you try the recommendations in this thread. I had confirmed with our Support Team that you have already an open case with them. Indeed, in this case the best is to continue the assistance with them.
