04-18-2016 15:48
04-18-2016 15:48
Hi,
Last night I charged my Blaze.
When I took it off charge it shows nothing on the screen.
I have tried every combination of buttons to power on and nothing happens.
When I put it back in its cradle there is nothing displayed on the screen.
Fitbit app says it is looking for the device.
Any ideas?
12-17-2016 08:31
12-17-2016 08:31
Battery died this morning. I tried the suggestion above but it never work! Shall I charge for full batt first before turn it on again?
12-20-2016 10:38
12-20-2016 10:38
Welcome to the Community Forums @Carmencheong 🙂
I'm sorry your tracker is not responding 😕
If you've already tried my previous suggestions and that has not worked, feel free to get in touch with the Support Team directly. They will be happy to take a deeper look and get you back on track.
Let us know if you need anything else!
12-23-2016 13:00
12-23-2016 13:00
Good advice from FerdinandFitbit, worked like a charm.
12-23-2016 13:08
12-23-2016 13:08
I just bought my Fitbit blaze today. Charged it, and everything worked while charging. I remove it from the charger and it does not turn on. I tried the hard reset that you said, but it still does not turn on
12-23-2016 14:23
12-23-2016 14:23
Same problem here. Last night it showed a half battery life. This morning it was dead as a doornail. Figuring the battery went flat, I placed it in the charger which shows a fully charged battery, back in the wrist holder and it won't turn on no matter how long I press the left and right buttons.
I have an extended replacement warranty, but honestly, try getting to the stores and getting one on Xmas Eve!!!! I love my Fitbit when it is working, but so tired of the unreliability that I just want to throw the thing in frustration.
12-26-2016 10:30
12-26-2016 10:30
Thankyou FerdinandFitbit i dont know what i would do i was about to dump my blaze
01-01-2017 17:41
01-01-2017 17:41
My Blaze just stopped working. I can't get it to go bck to the time. I had it on the timer mode. nOw it is stuck in hat setting. Hope someone can offer some advise.
esm1
01-02-2017 11:37
01-03-2017 02:28
01-03-2017 02:28
I am having a similar problem, noticed the screen was white during the night while tracking sleep, I put my Blaze on charge this morning, but the screen is blank, no sign of life and can’t turn it on. Tried holding buttons down 10 – 15 seconds but nothing..?
01-03-2017 09:53
01-03-2017 09:53
Huh, that is very strange @Mav007 😕
I would recommend at this point getting in touch with the Support Team for them to take a deeper look and I'm sure they will be happy to help you out with this.
Let me know if you need more help and welcome to the Community!
01-04-2017 18:59
01-04-2017 18:59
It worked!!
01-04-2017 21:50
01-04-2017 21:50
Thanks @FerdinandFitbit. It worked
01-05-2017 11:54
01-05-2017 11:54
Hey there guys @Carmencheong @Jaredwal47! I'm happy to hear that it worked for you! 😄
If you need anything else, let me know!
01-07-2017 15:52
01-07-2017 15:52
01-07-2017 19:43
01-07-2017 19:43
My Fitbit blaze won't respond. I tried doing the buttons sequence and nothing.... it stopped responding once I went into the app to change the screen layout for the clock.... please help
01-08-2017
12:45
06:56
01-08-2017
12:45
06:56
Hi there @Jaredwal47 @Beau1010. Welcome to the Community! 🙂
@Jaredwal47, to make sure the time is correct on your Blaze, go to the account section on your app, go down to Advanced Settings, then go to Time Zone and make sure that your time zone is correct and after that, get your tracker to sync for it to show the correct time.
@Beau1010, If your tracker is not responding even after trying to restart it, feel free to get in touch with the Support Team for them to take a look and help you out with this.
Let me know if you need more help!
01-20-2017 21:51
01-20-2017 21:51
My Blaze wont turn on once removed from cradlle. It seems fully charged...five hours and battery icon gradually became full but as soon as I remove it from the cradle it goes dead. I tried starting by holding left and right bottom button but nothing.
01-21-2017 00:00
01-21-2017 00:00
Hello @seanomara see @FerdinandFitbit's post above your post, it sounds as if your tracker is not responding.
01-28-2017 12:48 - edited 01-28-2017 12:51
Yayyyy! My Fitbit blaze is back in business. Now I can get back to stepping. Thanks @FerdinandFitbit
01-30-2017 04:45
01-30-2017 04:45
I'm very happy to hear that it worked for you and that you're now back on track @Lewisgirl_RN! 😄
Anything else you may need, let us know and we'll be happy to help!
Happy stepping!
