10-16-2017
12:47
17:38
SilviaFitbit
10-16-2017
12:47
17:38
SilviaFitbit
Purchase my Blaze almost two year ago, the battery did last a week now I'm lucky if it last two days. What can be done to make the battery last longer. It's an inconvenience to keep charging it.
Thanks for your help. Holly Auger
A warm welcome to the Community @Hsarge! Thanks for the details that you've mentioned. I would like you to double check that you're properly charging it, also restart it. After this, you may want to check tips to improve your battery.
Hope this helps! Keep me posted.
Mine did the same thing. It was attempting to sync without success. I suspect a software issue at FitBit.
I was given the canned response to charge it with a computer.
I told the bot that 5 volts is 5 volts.
The bot's response.
"I am not familiar with the voltages of your Charger, Michael. But charging the tracker in a different way whether the voltage is the same will affect the battery life of the tracker."
Charge control is internal to the Blaze and not with the computer.
